Steering grearbox leak question
Looks like I have a seal leak in my PS gearbox. Dry around the hose connections but dripping off the end of the Pittman Arm shaft. I have a new lower seal repair kit but have not attempted this yet. Any suggestions? I know I need a Pittman Arm puller. How tough is it to get the lower seal out and replace it? Any help appreciated.
Thanks, Larry |
Re: Steering grearbox leak question
Has nobody tried this? Is everyone replacing the gear box?
Thanks, Larry |
#3 | |
Global warming is a myth
![]() Quote:
For my money, (& time), it's worth it to me to just replace the whole thing. HTH, Buddy
Henderson, NV 1972 K5 - Lifelong project - Needs Time, Place, Help & Parts!! 1990 K5 with 37's 2003 Discovery SE7 - Wife's |
FORD is a 4 letter word.
Replaced the top seal on mine in truck. piece of cake. Dunno about the lower.
'71 406 GMC Short Box Fleetside - Daily Driver '79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com '58 LT1 Chevy Short Box Step Side - Next Project |
Top seal=easy, bottom seal=***** (didn't work either) , replace unit=warrenty
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
Yes, the whole gearbox has to come apart. Then you have to make sure you center it correctly when putting it back together. And also set up the preload properly. If you don't get it right it won't work right. Not worth the effort. Now would be a good time to upgrade to a newer, quicker ratio box.
I plan on replacing my gearbox this weekend - any tips? Is it just an unbolt > remove > install new box > bolt up project?
Yes, a simple bolt and unbolt. If you use a newer o'ring style box, make sure you get the hoses too. Then just splice the new high pressure hose onto your old pump side at the steel with a compression fitting.
Thanks for the help. I will look into a new gearbox.
Larry |
SB406 How did you replace that top seal without taking the whole thing apart?
