Old 07-27-2006, 03:47 PM   #1
crustysarge
Aftermarket Water Temp Sensor Install
I need to install an aftermarket sensor but am keeping the stock one in the head. Good location on the SBC where to install?
crustysarge is offline   Reply With Quote
Old 07-27-2006, 04:06 PM   #2
SB406
FORD is a 4 letter word.
SB406's Avatar
Re: Aftermarket Water Temp Sensor Install
What are you using it for? Fan? gauge?
Another plug in the head (or other head) is an option. Or the intake manifold.
Keep in mind, If you put the sensor in the head, it will read about 10 degrees F higher than if you put it in the intake. That's why I ask what it's for. For example, if you want an electric fan to come on a little sooner, put it in the head, I little later, the intake...etc.
'71 406 GMC Short Box Fleetside - Daily Driver
'79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com
'58 LT1 Chevy Short Box Step Side - Next Project
SB406 is offline   Reply With Quote
Old 07-27-2006, 04:15 PM   #3
70GMCer
70GMCer's Avatar
Some may disagree with this, but I put my after market sensor in the bottom of the radiator where the drain is.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 07-27-2006, 05:19 PM   #4
redandwhite_72
70GMCer -- What's the point in putting it in the bottom of the radiator? That's where the coolant is the coolest. So there is really no point in that.
redandwhite_72 is offline   Reply With Quote
Old 07-29-2006, 03:56 PM   #5
crustysarge
For an aftermarket gauge. Guess I'll use the head location or maybe the thermostat housing plug.
