Old 07-27-2006, 06:30 PM   #1
cst70rocket
Best/Most Affordable AirBag Setup
Ok, I'm new to bagging one, so I've only looked on the net. Is there a vendor who I can buy a complete kit from for the front and rear of a '65 short wheel base panel truck? Anyone associated with the board?
cst70rocket is offline   Reply With Quote
Old 08-06-2006, 02:40 AM   #2
cst70rocket
Re: Best/Most Affordable AirBag Setup
I get it, it's a secret:bansex: :bansex:
Old 08-06-2006, 02:59 AM   #3
dwcsr
Hollister Road Co.
dwcsr's Avatar
try fatman fabrication
dwcsr is offline   Reply With Quote
Old 08-06-2006, 08:36 PM   #4
98L150
///Relaxed Atmosphere
98L150's Avatar
air ride technologies
www.ridetech.com
72 Suburban
64 Chevy short fleet
04 Chevy Colorado Sport Reg Cab
2012 Chevy Avalanche
2003 Chevy S10 Blazer Xtreme
http://www.hubgarage.com/mygarage/RA_Jeff
64 Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=295915
98L150 is offline   Reply With Quote
Old 08-06-2006, 10:10 PM   #5
jasonrmorrow
Having just mostly completed this job (all i got left is the brake lines...did a disc swap same time)...lets see if i can help out...
are you disc'd already ?? dropped spindles ?? happy with current braking setup.
If all you want to do is bag the truck the shopping list is very very short...
- 4 x firestone 2600 lb 224c bags, single 3/8ths port, single 3/8ths threaded boss on the bottom plate.
- set of 73-87 bag plates and cups...mine were $80 cdn for all 4
- go to your local industrial hose headquarters or ability hose or something...
get 4 x 90* 3/8ths to 1/4 hosefittings, your choice...push to connect or swagelock, I prefer swagelock myself, easier to get the system airtight,
4 x 1/4"schraeders..again ptc or swage and about 30 ft of 1/4" airline just to be safe and have lots of extra...its cheap
- if you want to "t" the rear, and only ever do the rear (one schraeder to fill both bags) then pick one up here too, don't "t" the front
- you'll need either red thread locking agent or teflon tape for the swagelocks
- and a fresh razor blade to cut a perfect sqaure/clean airline
The extras that may come in a truck dealers kit would the Early Classic Super track bar, and the shock relocater kit. Other than that its all off the shelf parts.
Now if you want to get into valves and compressors and tanks then you add to that basic system. There are guys who have done this a few more times than i have on this board but if you just want to put bags on an otherwise stock frame i can help you out.
As it sits in the picture below it has 3" dropped spindles, 26" tall tire and bags, and the control arms are on the ground. The back has no notch and the frame iis resting on the axle. I'm going to get a pipe notch done in the back so it'll sit down more when its dumped.
It still has full length headers on it, with it dumped i can't get my fingers underneath the headers....time for shorty's or 3/4's. The blazer tank in the back is also only about 5 inches off the ground.
1964 - LWB 350 TPI Fuel Injection
On airbags
jasonrmorrow is offline   Reply With Quote
Old 08-09-2006, 11:10 PM   #6
zenish
how much were the bags?
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 08-09-2006, 11:33 PM   #7
jasonrmorrow
I paid $120 taxes in locally, In Calgary, Canada, so you'll get better prices in the states Somehwere around $90-100. I also got 2 bags through work at "our cost" for $99.99 a bag.
I ordered a viar 400 compressor, 6 3/8ths SMC valves, a 5 gallon tank and two dual needle gauges today for $750 CDN taxes in. I also got a great deal from a custom shop. I kept all receipts the bags were the easy part, the disc swap is tougher, brake lines/booster setup is tough.
On airbags
