Old 07-27-2006, 10:42 PM   #1
tx69gmc
Firewall transplant?? What would you do?
OK. Here's the deal. Has anyone ever done a firewall transplant? My current truck's firewall is pretty chewed up and I would like to replace it. I have a donor cab that I can either take pieces from or completely refurb and put on existing chassis. What would you guys do? Thanks
tx69gmc is offline   Reply With Quote
Old 07-27-2006, 10:53 PM   #2
ChevyCrazy67
ChevyCrazy67's Avatar
Re: Firewall transplant?? What would you do?
I think if it was me I'd just swap cabs if it's got alot of rot on it, and the donor cab is in better shape. just my 2 cents, but anything is doable with a little determination and alot of cussin.
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 07-27-2006, 11:05 PM   #3
67chevy2wd
67chevy2wd's Avatar
I was gonna suggest a cab swap also, much easier than swaping firewall. But this all depends on which cab is in better shape. If the firewall is the only thing wrong with the original cab then I would swap firewalls. Unless the donor cab is premo.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 07-27-2006, 11:12 PM   #4
tx69gmc
Donor cab is not perfect but will need to be blasted or dipped and rockers/floor pans replaced. Firewall on donor is about as good as I have seen. How would you go about cutting out the firewall?
Old 07-28-2006, 03:38 PM   #5
tx69gmc
Ttt
Old 07-28-2006, 03:58 PM   #6
cdowns
cdowns's Avatar
if i was going to mess around with a firewall i'd just notch it out and smooth it so i could move the engine back a couple of inches for a better weight distribution
Old 07-28-2006, 04:34 PM   #7
matthufham
with the firewall off, the only thing holding the truck in shape would be the windshield frame and rear... if you can brace it well enough to maintain the shape, try it.
matthufham is offline   Reply With Quote
Old 07-28-2006, 04:38 PM   #8
HuggerCST
HuggerCST's Avatar
I've done it on other trucks, but not a 67-72. It's not that hard, just cut it in the windshield posts and across the floor between the door openings. That's the easiest way. Be sure to measure twice and cut once., and make sure that your doors fit before final welding. I have a 72 blazer that I plan to do this to one day. Of coarse, you'll also have the vin tag to deal with.
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
