Old 07-28-2006, 05:16 PM   #1
Firefighter633
power brake booster for 72 chevy pick up
Hi guys. I´m working on my new 72 chevy truck, want to install a brake booster. Problem is, on my firewall there are 4 bolts coming out into the engine comp. and the boosters I can get here, also has bolts on it... What I need, I think, is a booster with some sort of mount that will attach on the bolts. Anyone done that little trick? And where do I get that booster?
Firefighter633 is offline   Reply With Quote
Old 07-28-2006, 05:24 PM   #2
ChevyDude
Re: power brake booster for 72 chevy pick up
You need the bracket that goes on the firewall and the 4 bolts sticking out. The bracket also holds the rod coming through the and provides leverage as it presses into the booster. The booster bolts into the other side of this bracket. Try the parts board...but you will have to be a subscriber to ask for the part!
ChevyDude is offline   Reply With Quote
Old 07-28-2006, 05:29 PM   #3
Botietruck
'71 chevy s.bed/s.side
Botietruck's Avatar
Here's a pic...not a good one, but gives you an idea of what you need. maybe someone else has a better pic.
STILL PLAYS WITH CARS...AND TRUCKS!!
Parents! Be good to your kids...they get to choose your nursing home!
250 I-6 with a 3 speed Saginaw and Borg Warner Overdrive...She's got overdrive!
Botietruck is offline   Reply With Quote
Old 07-28-2006, 05:41 PM   #4
Firefighter633
jep, I saw a picture somewhere like that one... Is the mount and booster one piece or do I get the mount, bolt on the booster to the mount and then the hole thing to the firewall? Would have put in a pic, if I wasnt such a moran using a computer...
Old 07-28-2006, 07:00 PM   #5
krue
Designated A-hole!
krue's Avatar
The bracket is separate from the booster. The bolts on the booster are for the bracket. Then the bracket bolts to the firewall. The bracket allows for the linkage to have room to operate. (I hope that makes sense )
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 07-28-2006, 07:09 PM   #6
70C10Toejam
Hellasick
70C10Toejam's Avatar
I got my booster outa junked '72. Figured the brackets etc. were worth it even if it doesn't work and need a core for a rebuilt.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
70C10Toejam is offline   Reply With Quote
Old 07-28-2006, 07:27 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Used boosters are a bad idea...esp the 3/4 ton and one ton daul diaphram units. I actually lost an engine to one.
Had engine running, it was a little lean, was waiting on a jet assortment kit, and one of the diaphrams popped while i was spinning 4 grand on the freeway.
BOOM
Found piston chunks in the oil filter.
Old 07-28-2006, 08:08 PM   #8
70C10Toejam
Hellasick
That pretty much sucks.
Have not yet installed mine, and if it dont work, its a core.
$25 for a core charge, and no brackets etc.
$25 for used with brackets etc.
in the end, its a wash, with brackets.
Old 07-28-2006, 08:43 PM   #9
truckdude239
truckdude239's Avatar
heres a little better picture of what you need u will need a new master cylider for the power brake unit
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-09-2006, 01:46 PM   #10
Firefighter633
Hi Guys!
Thanks for all the help. I´ve just ordered a brake booster kit from classic performance products, it has the bracket, the vacuum part and the master cylinder, so should be possible to fit on my truck...
By the way, I´m going to LA in september, anybody knows of some good parts shops or whatever in that area?
Old 08-09-2006, 02:08 PM   #11
Longhorn Man
gotta hit mooneyes, go to the perterson automaotive museum.... lots of stuff to do. Cruise ins every weekend, in-n-out burger, you gotta hit the junk yards... I could go on and on.
Old 08-09-2006, 02:27 PM   #12
Longhorn Man
here you go... http://67-72chevytrucks.com/vboard/s...d.php?t=185731
moon eyes was cool as hell!
the view from my hotel room;
The beaches were awsome;
the hard rock cafe was great (hottie waitresses too)
Plan it out, it's a fun place to go. Ignore the idiots in traffic, and have fun.
