Old 07-28-2006, 06:43 PM   #1
70C10Toejam
Hellasick
70C10Toejam's Avatar
Regarding the "easy disk brake swap " thread
http://67-72chevytrucks.com/vboard/s...ad.php?t=35042
Just why won't the '88-'94(?) 6-bolt rotors work with the '73 to '87 spindles. I ask cause I stripped a '85 frame for the brakes. Are the rotors too different to fit the spindle or what?
Would just prefer off the shelf parts to special ones. At this point it isn't worth the extra $$ to change now.
Just wish I had found this a couple years ago
70C10Toejam is offline   Reply With Quote
Old 07-29-2006, 05:19 PM   #2
Rydn2L0w
Active Member
Rydn2L0w's Avatar
Re: Regarding the "easy disk brake swap " thread
When I researched it last year I found the distance from the back of the rotor to where the rotor would sit against the spindle was different between the two years. I went to discount auto parts , compared and measured the two. So I figure the caliper would be in the wrong position if you were to attempt to use the later model rotor. There is a guy that used late model spindles rotor on a 1 ton 68 lower control arm on this forum somewhere, he listed all the parts he used. Try doing a search for it.
Rydn2L0w is offline   Reply With Quote
Old 07-29-2006, 07:39 PM   #3
70C10Toejam
Hellasick
That is the thread I am referencing, used 88 3/4 ton spindles, etc. But either missed the difference or no one said just why these rotors, that use the same bearings would not work on the 73-87 1/2 ton spindles.
I keep two MAGNUMS in my desk. One's a gun, and I keep it loaded. The other's a bottle and it keeps ME loaded. I'm Tracer Bullet. (Calvin and Hobbes)
This life was a test. It was only a test. If this had been an actual life, you would have received instructions on where to go and what to do.
RED meat is not bad for you...FUZZY BLUE/GREEN MEAT is bad for you!!!!!!!!!!!!!
BUILT FORD TOUGH WITH CHEVY STUFF--sticker at Goodguys
Old 07-30-2006, 03:33 AM   #4
Rydn2L0w
Active Member
Rydn2L0w's Avatar
sorry I noticed that after I responded and clicked on the link. Well hopefully my response answered your question. I was hoping to use a late model rotor on the early model spindle as well. If you find something different please let me know.
Old 07-30-2006, 12:15 PM   #5
70C10Toejam
Hellasick
Not a problem. Given the way the big 3 do things, the distance between the bearings could be different. Since the back-spacing is it different , is it too much to work with the stated 1/2 ton spindles and calipers? I think everyone here knows that just because there is a slight difference, doesn't mean it can't work.
Old 07-30-2006, 12:26 PM   #6
Rydn2L0w
Active Member
Rydn2L0w's Avatar
The two rotors use the exact same bearings. The problem is the spacing. If you bolt the 90s rotors to the 72 spindles. The caliper wont slide over the rotor. Maybe if you modify the 72 spindles and or make new caliper brackets? I think it would be much simpler to buy 6 lug rotors from cpp. That is a direct bolt on. I measured the two rotors side by side at the local discount auto parts before xmas last year. From what I remember they were both the same diameter and circumference. The only difference is the back spacing.
Old 07-30-2006, 12:34 PM   #7
70C10Toejam
Hellasick
I think that is what I'm gonna do. At cpp they are $65 each ($129 pair), which isn't that much more than these 3/4 ones. Especially if you figure the cost to modify the setup. Just like it isn't worth it to get the 3/4 ton setup with money already in the parts I have. Yeah, shipping is more. I just would have liked to buy off-the-shelf.
Old 07-30-2006, 12:51 PM   #8
Rydn2L0w
Active Member
Rydn2L0w's Avatar
That is the exact same reason I researched it. I wanted over the counter parts instead of mail order. Just didnt seem worth it to me. I dont have spindles yet,But I have ART strong arms with 73-87 ball joints . So the 3/4 ton parts wouldnt work.
