Old 07-28-2006, 07:37 PM   #1
Ironhorse
Ironhorse's Avatar
Original Manuals F/S
'69 Chassis Service Manual, some shop wear, no torn pages or marks.
'71 Chassis Overhaul Manual, some shop wear, no torn pages or marks.
$20 shipped each.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 07-28-2006, 07:39 PM   #2
Ironhorse
Ironhorse's Avatar
Re: Original Manuals F/S
'69 Manual
Wellington, Ks
Old 07-29-2006, 01:32 PM   #3
67chevy2wd
67chevy2wd's Avatar
What does it all explain how to rebuild, is it just the chassis as in the suspension or is there more?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 07-29-2006, 05:15 PM   #4
Ironhorse
Ironhorse's Avatar
For the '69 manual the index covers:
Gen. info and lube, heater and a/c, body, frame, front suspension/4wd, rear suspension and driveline, brakes, engine, engine cooling, fuel system, clutch and trans., fuel tank and exhaust, steering, wheels and tires, chassis sheet metal, electrical-body and chassis, radiator and grille, bumpers, accessories, and specs. Book is nearly an inch thick. Not sure if the pic helps or not, not a camera expert.
Wellington, Ks
Old 07-29-2006, 05:20 PM   #5
Ironhorse
Ironhorse's Avatar
For the '71 manual:
A/C compressor, 4-wd front axle differential, rear axle differential carrier, power brake cylinder, engine, carburetors, starting motor solenoid and decotron, trans. and clutch/ 4wd transfer case, steering gear, power steering pump and control valve, specifications. Book is nearly 3/4" thick. Pic may help.
Wellington, Ks
