Old 07-29-2006, 09:28 PM   #1
outacontrl86
1/2 springs and 3/4 ton springs the same?
i was wondering if half ton springs and 3/4 ton spring were the same lenth and the 3/4 ton ones be put in a half ton...also what front and rear ends does a 86 k10 4wd have in it i am thinking about getting some 373's for it
outacontrl86 is offline   Reply With Quote
Old 07-29-2006, 09:47 PM   #2
89 crew
Re: 1/2 springs and 3/4 ton springs the same?
I'm not sure about legnth but I'm pretty sure the 3/4 is wider, and I believe the center bolt is a different size
89 crew is offline   Reply With Quote
Old 07-29-2006, 09:52 PM   #3
outacontrl86
what do you mean buy center bolt?? i meant leaf springs if you were talkin about coils..sorry
Old 07-31-2006, 12:23 PM   #4
tgh117
Crazy
tgh117's Avatar
The center bolt is the bolt on that lines up the rear axle to the center of the leaf spring. That is why its called the center bolt. Keeps everything square so you can tighten the u bolts and have everything straight.
77 SB Stepside in a bunch of pieces scattered around the garage.
tgh117 is offline   Reply With Quote
Old 07-31-2006, 01:33 PM   #5
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
I dont think they will change out. There are two lenghts 52 or 56 in. Your K10 most likely has a gm 10 bolt 8.5 differenetial.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-31-2006, 02:58 PM   #6
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
3/4T springs are longer, so they won't work without moving the rear spring perch.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-01-2006, 12:06 AM   #7
outacontrl86
yes i measerd them today 52 inches. for the back but i am not sure about the front thanks
Old 08-01-2006, 10:33 PM   #8
Metallicamaro
Boil'n rice
My dad put 3/4 ton springs in his 1984 Gmc sierra 1500 2wd pickup.. I remember them using the torch alot, but other than that.. the rear end is the same... and everything worked out great.. the rear of the truck sits up 4 inches higher than before...
Metallicamaro is offline   Reply With Quote
Old 08-01-2006, 10:37 PM   #9
magnethead
7000 #'s of american IRON
magnethead's Avatar
thinking i already know the answer, but can't you just re-arch the leafs to fit the smaller length, using a come-along or other similar device?
magnethead is offline   Reply With Quote
