07-29-2006, 10:52 PM | #1 |
Junior Member
Too many crossmembers?
I have a 67 c10 2wd that was oringinally a manual three on the tree. Years ago I had a auto trans installed with a b and m shifter. I recently have been trying to install a auto van tilt column. Well the column is in and I am trying to install auto shift linkage and if I am doing it right it seems that the front crossmember is in the way. Am I correct in this or am I doing it wrong. Can somebody please post some pics of their shift linkage at the frame to trans. Thank you very much.
67 short bed fleetside/1997 c1500 exteded cab/ 2004 accord/87 c10silverado 350 od tbi |
07-29-2006, 11:57 PM | #2 |
Re: Too many crossmembers?
are you saying the manuat trans crossmember was not removed when the auto was instaled if so remove it for the needed clearance
common sense isn't so common anymore |
07-30-2006, 12:36 AM | #3 |
Junior Member
well there is one towards the front of the trans even with where the trans shifter is and one for the auto trans mount
07-30-2006, 11:50 AM | #4 |
Not sure but maybe the mechanics for the clutch linkage, (z-bar) was left in because they were using the B & M shifter and didn't need to worry about it being in the way of the linkage from the column. Just a guess on my part.. But the only thing that I can envision as getting in the way of the linkage.
By the way "Go Chargers"
Smitty '71 Short Fleetside Spring Valley, Ca. |
07-30-2006, 12:01 PM | #5 |
Sounds to me like you didn't remove the 3 speed crossmember. It is right below the firewall. I just changed my 3 sp. to a 700r4. 3 sp. crossmember has to be cut out and an "Auto" crossmember has to be put in. Linkage should not be a problem when this is done.
