Old 07-30-2006, 03:31 PM   #1
1969C/10
Unskilled Labor
1969C/10's Avatar
Bed For My Truck
I'm going to get rid of the 1992 bed on my truck and going to get an original bed. I don't know what kind I'm getting, would either stepside or fleetside work? Also, will any short bed 1967-1972 fit or only particular years? Also, what hardware will I need for this swap? Thanks in advance.
1986 K/20, 350/TH400, My First 4x4.......
1969C/10 is offline   Reply With Quote
Old 07-30-2006, 03:42 PM   #2
tom71
what happened to flint mi
tom71's Avatar
Re: Bed For My Truck
good move . either bed should work , the earlier beds wont have the side marker holes in the fenders , i would think you would need mounting hardware and mounting pads is the harness stock for the lites ? is the tank back there ?
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 07-30-2006, 03:51 PM   #3
1969C/10
Unskilled Labor
1969C/10's Avatar
No the tank is up front, so that shouldn't be a problem. Not sure on the wiring harness for the lights. Are 1967, 1969, and 1971 stepside beds identical? Are 1967, 1969, and 1971 fleetside beds identical? Thanks.
Old 07-30-2006, 03:56 PM   #4
Hart_Rod
Hart_Rod's Avatar
Either bed will work, depends on what look you are going for. Stepside would probably be cheaper. SWB are kinda pricey whether new or used. MAR-K builds a nice step side bed (I've bought 2, see my link). Goodmark sells most of the stuff to build a SWB.
R
Hart_Rod is offline   Reply With Quote
Old 07-30-2006, 06:11 PM   #5
68GenIII
A good swb rust free bed is hard to come by. I just used a good lwb bed and made my own.
http://www.gmhightechrides.com/cgi-b...?m-1152644049/
68 lwb to swb Cummins swap in the works. I promise it will be cool someday.
68GenIII is offline   Reply With Quote
