Old 07-30-2006, 04:50 PM   #1
67chevy2wd
67chevy2wd's Avatar
4" front drop?????
If I drop my 69 4" in the front am I gonna have any troubles with the front sway bar?
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 07-30-2006, 04:59 PM   #2
ChevyDude
Re: 4" front drop?????
Not if you get ECE lowered mounts for your sway bar. Mine is dropped 4.5". My lower "A" arms at the lowest point are only 3.5" off the ground.
ChevyDude is offline   Reply With Quote
Old 07-30-2006, 05:04 PM   #3
67chevy2wd
67chevy2wd's Avatar
I suppose i should mention i am going with 2.5" drop spindles
'71 GMC 3/4 ton 4x4
Old 07-30-2006, 05:10 PM   #4
ChevyDude
My truck has ECE 2.5" drop spinds and 2" drop Ground Force springs. You should be fine. The ECE lowered mounts are not too expensive and it is possibe that you don't even need them. ECE has great Cust Serv...talk with them when you order your Spinds!
Old 07-30-2006, 05:21 PM   #5
67chevy2wd
67chevy2wd's Avatar
Could I see a side shot of you truck? I am undecided if i want to go 4" or 4.5" in the front.
'71 GMC 3/4 ton 4x4
Old 07-30-2006, 05:44 PM   #6
ChevyDude
Sorry, I don't have a very good side shot. Truck is still in build process and has only been outside of the garage with the bed off. Maybe someone else can post a nice pic of a 4" front drop???
Old 07-30-2006, 07:08 PM   #7
Hart_Rod
Hart_Rod's Avatar
I saw a trick where a guy drilled out the rivets on the original sway bar mounts and then mounted the sway bar on top instead of on the bottom. Pretty ingenious and cheap! Wish I had thought of it.
R
Hart_Rod is offline   Reply With Quote
Old 07-30-2006, 07:36 PM   #8
67chevy2wd
67chevy2wd's Avatar
like inside the original mounts?
'71 GMC 3/4 ton 4x4
Old 07-30-2006, 07:39 PM   #9
Hart_Rod
Hart_Rod's Avatar
Yes
