Old 07-30-2006, 09:03 PM   #1
chris carroll
4/6 drop questions
i want to drop my 72 lwb with a 4/6 drop kit. the only thing is that i only find ones for rear coil spring, and my truck has leaf's in the rear. so if im just looking in the wrong place will some one please point me in the right direction.
thanks-Chris
chris carroll is offline   Reply With Quote
Old 07-30-2006, 09:48 PM   #2
5150
C10 Club Tennessee
5150's Avatar
Re: 4/6 drop questions
you don't really need the kit. They are nice, but you can do it a little cheaper then the kit if you are on a budget.
You'll need a set of 2.5 drop spindles, rear shock locators and an adjustable panhard bar. You can cut one coil off of your front 2 coils.
About the lowering leaf kit-I'm not sure. You might want to see what a set of bags cost for the rear. Some one around here must have done this drop with leafs.
Also Welcome to the Board!!!!
Bryan
www.gmtruckshow.com
Project "Andes"-Halen's First Truck
Project: Patina Burb
for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4
5150 is offline   Reply With Quote
Old 07-31-2006, 05:00 PM   #3
see ten
WTB this ad
see ten's Avatar
Mmmm Bryan, Leaf spring trucks don't have a panhard bar. The rearend is centered by the leaf packs. I know a lot of the 73-87 guys are moving the axle from under the leaves to above for about 6" of drop. I am pretty sure this just all but requires the use of a C notch in the rear. Try contacting Tim Christian about the drop on his green GMC. It's a leaf spring truck thats stance is right on! I spoke with him while we were in Maggie Valley about the drop on his truck but I believe I was working on a pitcher of Margaritas at the time so things are a little fuzzy.
see ten is offline   Reply With Quote
Old 07-31-2006, 08:10 PM   #4
5150
C10 Club Tennessee
5150's Avatar
My bad, didn't know that. Learn something everyday. Best thing Chris is to get in touch with Tim Christian and see what kind of kit he offers. www.christianclassics.com
Bryan
www.gmtruckshow.com
Old 07-31-2006, 10:57 PM   #5
72MARIO
72MARIO's Avatar
You can use a 73 up flip kit with a little grinding. A notch would make it ride nice nut I dont hav one and it wad my DD till Last week when I took out the 2nd 700R.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 08-01-2006, 12:43 AM   #6
corn
I flipped the rear on my 69. I used a '73-'87 kit & had to grind a little off each corner, The 73-87 perches are wider than on the older trucks. If you use a flip kit they are designed to move the axle back to center & correct the pinion angle. Heres a pic of the flip kit & a pic of my truck. It has 3" springs in the front & another inch of drop in the front would level it out a little better...corn
BTW, the frame isnt notched either. If you drive it like a car & dont haul heavy loads it will be fine...
corn is offline   Reply With Quote
