Old 07-31-2006, 10:52 AM   #1
cwilkie
Chance
cwilkie's Avatar
Is a 4x4 frame the same as a 2wd frame?
I have a friend who is wondering if a 4x4 frame is the same as a 2wd frame. He has a 4x4 and there is something wrong with the frame. There are many 2wds around here but next to none 4x4. He's wondering if he can swap in a 2wd frame and just bolts on the 4x4 components.
Chance
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 07-31-2006, 01:34 PM   #2
Livrat
Member #1049
Livrat's Avatar
Re: Is a 4x4 frame the same as a 2wd frame?
The frames are not the same, 2WD frames bulge out in the rear where the 4X4's are straight.. It will not be a "bolt in" swap, But it is possible with alot of work, you can remove all of the spring hangers, mounts and crossmembers and drill tons of holes and put it all on a 2WD frame..
Livrat is offline   Reply With Quote
Old 07-31-2006, 01:38 PM   #3
67chevemall
67chevemall's Avatar
big job! look harder for a 4X4 frame
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 07-31-2006, 03:38 PM   #4
extd56
extd56's Avatar
How about using a GMC frame that has rear leaf springs? I believe the front should bolt on.
extd56 is offline   Reply With Quote
Old 07-31-2006, 05:13 PM   #5
67chevy2wd
67chevy2wd's Avatar
Where is belcourt at in ND. I used to know but have forgot. If I remember right New Salem played them in basket ball and possibly football when we were still 11 man.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 07-31-2006, 08:52 PM   #6
badpeanut
Not a bad nut after all..
badpeanut's Avatar
I believe 4x2 leaf rear trucks use the same frame as coil rear trucks.
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 07-31-2006, 09:16 PM   #7
extd56
extd56's Avatar
A coil spring frame is a lot different in the back than a leaf spring truck, I have 2 of each so it is easy to compare.
Old 08-01-2006, 08:23 AM   #8
badpeanut
badpeanut's Avatar
No, see http://www.earlyclassic.com/Tech.asp...=Spring%20Time
'70 GMC LWB trailer
Old 08-01-2006, 10:36 AM   #9
cwilkie
Chance
cwilkie's Avatar
Belcourt is at the top center of North Dakota and about 20 miles south of the Canadian border. Another way to look at it is Belcourt is about 35 miles north of Rugby, North Dakota. Actually, it is located on the Turtle Mountain Indian Reservation. So...Yes...I am Native American!
BB 396 w/TH400
BB 496 w/TH400
Old 08-02-2006, 12:01 AM   #10
72 CustomCamper
huh ???
72 CustomCamper's Avatar
Here are 2 pics. The first is a 4x4 frame. The second is a 2wd coil spring frame. Major difference in the rear...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's
"I am a bomb technician. If you see me running try to keep up!"
72 CustomCamper is offline   Reply With Quote
Old 08-02-2006, 02:57 PM   #11
6T8
Active Member
Everyone is forgetting the rear shackle mount on the front spring. Frame is also different there. Based on experience, keep looking for 4x4 frame. I have one but Tucson might just be alittle far to drive.........Rick
6T8 is offline   Reply With Quote
Old 08-05-2006, 12:50 PM   #12
6869704X4
What are the differences there? I am looking for a frame and was under the impression that they were the same.
Maybe someone can post some pics of that area?
The more I learn about women, the more I love my truck.
6869704X4 is offline   Reply With Quote
Old 08-05-2006, 10:35 PM   #13
72 CustomCamper
huh ???
On the 4x4 and leaf spring frames the frame rails are straight. Pic 1...
On the 2wd coil spring frame the frame have a curve in it for the springs to sit on. Pic 2...
Old 08-06-2006, 08:15 PM   #14
6869704X4
Thanks 72CustomCamper, but I was asking about what 6T8 said about the rear front spring mounts. The aft part of the frame is easy to spot as far as the difference between coil and leaf.
