Old 08-08-2002, 08:50 AM   #1
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
I need to lighten up
I know some people say that fiberglass takes away from the value of our trucks, but I value my truck very much, fiberglass or not. But my truck definitely needs to go on a diet. What are some ways to lighten it? I was thinking a fiberglass hood, but what other parts can I buy in fiberglass? Who's got the best/cheapest fiberglass parts?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh...
bigcarguy is offline   Reply With Quote
Old 08-08-2002, 09:06 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Try US body, I think they are in Florida. They have a whole front clip for about $1200. I believe their site is www.usbody.com .
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 08-08-2002, 10:19 AM   #3
XXL
Seņor Member
XXL's Avatar
Re: I need to lighten up
Are you lightening up to go faster? If so, you could "lighten up" the truck a lot by swapping out that 307 for something with a little more umph...
Otherwise, US Body, who also has a lightweight cab, doors, bed, etc., and then swap in plexiglas for your rear and door glass.
After all that if you still have money, tube frame.
Kenneth
XXL is offline   Reply With Quote
Old 08-08-2002, 10:57 AM   #4
bigcarguy
Finally a Bulldawg
bigcarguy's Avatar
A little more umph would be nice, but I'm not swapping out the 307. Everyone swaps out their 307, no one actually tries to get power out of them. Different is good.
Old 08-08-2002, 11:33 AM   #5
XXL
Seņor Member
XXL's Avatar
Yeah, but the fiberglass listed above will cost you close to $10,000 and you're still not going to be fast as a result. I'm not knocking your interest in keeping the 307, but if your objective is fast, that's simply the wrong engine for the job. It's not built for high RPM (which is how you make a small displacement engine fast), and it's not build for excessive crank load, and it's not built to flow lots of fuel/air. But it makes a great reliable work engine...
Kenneth
Old 08-08-2002, 11:39 AM   #6
stea
Try www.creativeglas.com they carry alot of 67-72 parts. Im having them make a 1 piece tilt front end for my '39
stea is offline   Reply With Quote
Old 08-08-2002, 12:48 PM   #7
Low69CST
Why exactly does your truck need to go on a diet? If you want to go faster, you'd be better off spending time on tuning and upgrading your engine or getting a 400ci or 350ci and spending money tuning that engine. You could spend thousands of dollars on fiberglass body pannels, and gain only a few tenths at the drag strip. Body pannels are the lightest parts of your truck. The most $$ efficient would be to relocate the weight you have. Moving the gas tank, battery ect is a good start.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
