Finally a Bulldawg
Performer RPM intake
Is Edelbrock Performer RPM Intake(the high rise, dual plane) good for daily driving? I'll be running new heads(Torquer S/R 305) and a mild cam. The heads will bring the compression up a little, so I thought maybe I could squeeze more power out of a Perf. RPM than the regular Edelbrock Performer intake. This is a smaller inch engine(307) if that helps. Thanks.
Ah yes, the college life. School all morning, work all night, study when ya can. Uh... ![]() |
Your going to need more cam. I did the RPM on a stock cam, 1406, headers, and heads and could not get it to run right. Go with the Performer, it's much better.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
I agree. The Performer will work best in the idle-5500 rpm range, as where the RPM does 1500-6500...for a small semi stock SBC, do the Performer.
![]() Join Date: Jul 2000
Yep. Use the Performer or new Performer EPS. The Performer RPM likes big heads, hot cam, and low gears. Read Edelbrock's Power Package info on their web site. It stresses matched components.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
its all about the +6 inches
I've had both intakes on both stock and modified engines, you'll want the performer for a mild cammed moter.
![]() Join Date: Dec 1999
Regular Performer!!!
