Removing stuff to paint
Having some troubles removing a few things and before I started breaking stuff figured I'd ask here.
The dash gauges, how to unhook the wires in the back? I fiddled and got the speedo unhooked but the tach/oil psi/etc I need to unhook too and "fiddling" didn't get it so I need specific help on those. The grill? Where are all the bolts to get it off? Don't wanna bend it ![]() Ditto bumper (think I have that one figured but wanted to ask if there were any gotchas). |
Re: Removing stuff to paint
The grill should have a couple of bolts on each side 1 top and 1 bottom that bolt through the side into the fender. then a couple (might be 4 can't remember) in the middle where the hood latch is top and bottom bolted through the core support.
For the bumper if it hasn't been banged up and rusted bolts you should be able to take the one's you see from the front out and you'll have it. I had to heat mine to get them loose. As for the gauges better let someone else answer that one I haven't got that far yet myself.
Kevin 1967 C-10 swb fleetside 1968 C-10 stepside 1999 Z71- sons dd 1999 2wd silverado-my dd 2003 Tahoe- wifes dd |
I squirted all the bolts I could see for the grill and bumper with wd40 last week a couple times throughout the week so hopefully they'll brake loose REAL easy.
That grill fits tight it seems. That dash though I played with that baby for quite a while and didn't get it all unplugged. I got a new dakota digital dash to replace it with. My paint is here, got plenty of roller pads and latex gloves and sand paper, tomorrow starts the paint! Redneck rolled paint extravaganzza! Pics will be posted: http://faith.dixiesys.com/72GMC As I remember to take them anyway ![]() Last edited by Gary; 07-31-2006 at 10:03 PM. |
I survived Dead Man's Curve.
The dash has ONE main electrical plug that should be as easy as squeeze and pull. Oh wait... 30+ years old. Ok, better move it end to end. Should come righto ut. Also, your oil gauge line. GOnna need a small wrench. That oil tube doens't give much slack.
"The people should not be afraid of their government. The government should be afraid of it's people." "The Hurricane" 1967 Chevrolet C10 350 Eight Cylinder, 700R4 BowtieOverdrive Cherry Bomb... Disturbing the Peace Since 1968. ![]() |
got the dash out, got the ac controls out, ripped out the cd player (in pieces, I lost my temper, it wasn't staying anyway), dropped the steering column down so I can sand and paint at least the part what shows, everything but the fasdfafraking ignition switch. I even got the vent windows out.
Broke the windshield getting it out, it was to be replaced anyway, it was milky around the edges but I was kinda wanting to keep it in one piece in case someone on the board mighta wanted it. The rear window is in one piece at least, course I have a new tinted sliding glass window going back there still new in the box... Once I'm done I'll have an online yardsale for the extra parts ![]() Oh speaking of GRILL found a pretty nice chrome grill and eyerings on Ebay for $225 shipping and all! Jumped all over that. Even if it needs a little buffing and polishing those new chrome grills are ...!! my lord expensive. Now I just need a nice tailgate, gonna paint mine but it really ain't worth painting ![]() |
#6 | |
FORD is a 4 letter word.
Are you actually going through all this trouble to paint it with a roller? If you are...that's cool...different strokes for different folks... I just feel like I'm missing something.
'71 406 GMC Short Box Fleetside - Daily Driver '79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com '58 LT1 Chevy Short Box Step Side - Next Project Last edited by SB406; 08-01-2006 at 04:16 PM. |
Sure why not, it's simple, I ain't paying 5grand++ to get it painted, I want it painted, I don't have a booth, you can roll easier outside than spray, rollers = pennies and no special knowledge required, spraying = guns and thinners and mixing and hardeners and other stuff I know nothing about, and dudes are having real good luck with foam rollers and thinned rustoleum, so here goes nothing
![]() And paint is only as good as the prep, so I want to at least try and have it mostly rust free/straight before I paint it, roller or sprayer or however. Here's some examples of 3 cars a dude did: http://s32.photobucket.com/albums/d13/69martin/ If I can have my truck looking HALF as good as that charger's paint I'll be tickled pink. Last edited by Gary; 08-01-2006 at 04:29 PM. |
Not sayin there's anything wrong with it.
Just the only roller jobs I ever saw were poorly done. Those cars look pretty damn good! I was checking out some of your truck pics before. Are any of them after your painting? If not, I'd like to see some when you're done. How do you get a smooth glossy finish?
'71 406 GMC Short Box Fleetside - Daily Driver '79 350 Chevy K-5 Blazer - On-going Project (Mudder)www.wnyoffroad.com '58 LT1 Chevy Short Box Step Side - Next Project |
#9 | |
Apparently you wet sand, then polish like a madman to get a good shine. RO buffer is a definite must have apparently. |
#10 | |
Active Member
#11 | |
For less than $800 it's a no brianer I'll let maaco/peach/earl schieb/whoever shoot it for me and call it done. |
its all about the +6 inches
The rustolium is very good paint, and if you roll it on right, no one will ever know that you did it like that. I've seen one done up, and it was a 12 year old paint job... it looked great.
I've considered it over and over on my rig. |
#13 |
As for the ignition switch, put the key in, turn it back to the acc position (counter clockwise) then insert a thin allen wrench or a paperclip into that small round hole on the cafeplate. You'll feel a spring loaded plate. Pres on the plate, as you turn the key further to the left, and it should pop out into your hand. May take some cussing and a few tries, or it'll jump right out the first time.
Once you've done that, you can remove the chrome bezel. |
#14 |
Oh FURTHER to the left, ok that was my mistake
![]() Here's that dart the dude did, finally got the link to it again: http://www.flickr.com/photos/xit1965...7594131616795/ |
#15 |
http://faith.dixiesys.com/72GMC/PICT0004_001
Decided to smooth over the side lights, just took some mesh cut it to fit and just screwed it in place with the screws from the lights, and started slapping some bondo on. On that subject, my god that bondo is some wicked stuff it starts to set up on you while you're just standing there slack jawed... The moral is definitely mix a LITTLE at a time! |
#16 | |
Active Member
#17 |
I'll second that!
#18 |
So my just screw some mesh in there idea ain't gonna fly eh? Ok guess I'll see about getting a welder and learning how to at least tack weld some stuff, been wanting to anyway.
#19 |
You should try learning on something that is of NO value. Learing on a fender you plan on keeping is a bad idea. You'll blow a hole in the metal, and then you'll have to patch it up, plus you'll heat everything up so bad it'll warp like crazy....
An old fender maybe? |
#20 |
Whatever happened to stick welding haha, used to watch my granddad do that and it looked easy enough. Yeah I'll practice some on something else first.
#21 | |
Active Member
#22 |
Well rolling my truck probably is not gonna happen, I found a local tech school offering night courses in Auto Body, $150, 16 week course, 3 hours once per week, the first thing the instructor asks us?
"What's your project?" meaning "what are you gonna paint while you're here?" State of the art paintbooth, the best paintguns (apparently they're like $700 each to buy) all the tools, frame machine, gonna learn to weld, all we gotta supply is the materials that are used up (sandpaper/paint/primer/tape/etc). I'd be a fool not to take this oppurtunity. One dude, this is his -5th- time taking the class, he's painting his 3rd car hahaha. |
#23 |
PROUD TO BE A MEMBER
HEHE Good Luck Dixie glad its all working out and dont show then the soft foam tricks unless they give you a discount
smiles Dick |
