Finally a Bulldawg
Shift kit drilled for street?
I bought a shift kit for the TH350 in my old Camaro many moons ago, but never got the chance to install it. Well, it's dead now but I still have the kit. It's already been drilled for street instead of towing. Would it be ok in my truck, or should I get another one and drill it for towing?
Ah yes, the college life. School all morning, work all night, study when ya can. Uh... ![]() |
![]() Join Date: Aug 2001
depends if you want extra firm tire chriping shifts or just firm shifts...
Smooth68's Web Site WTB 64-66 project or frame/cab, SWB or LWB...I have the fever! Whatcha got?? '68 Short Step - Shaved Body, Soon Bagged - SOLD Driver-2004 GMC Z-71 Ext-cab |
I always put in kits on the street/strip setting.
Makes the band hold a bit more and under load it helps.
Life is good with a 6-71 supercharged 355 in a 72 camaro ![]() |
#4 | |
Led Sled! Discs R 4 ME!
![]() Join Date: Jan 2001
I've always ran street/strip.It would shift firm while normal driving and bark the tires when you shift at upper RPM's.Not sure what the advantage of the RV setting would be.
Suburbans RULE!
Same here.....I installed my shift kit and used the street/strip separator plate. I've towed with it, it shifts hard and will chirp 2nd.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
What brand of shift kit is it?
The B&M and TCI valve bodies will shift hard at all throttle points. The trans-go will shift harder as more throttle is applied <-- I like this ![]() Also it depends on if you want full manual, or manual/automatic. |
![]() Join Date: Oct 2001
You cant even tell I have one installed unless you are full wide open. Then it chirps quite well.
#9 | |
