Old 07-31-2006, 07:38 PM   #1
chevybill
chevybill's Avatar
Talking People with gringoloco gauge setups.
As you know this setup uses a 3 hole bezel, with a speedo quad gauge and tach in the middle.
What type of arrangement is there for the high beam indicator and the signal indicators? Do you have to come up with something on you own or just do without?
Thanks for the replies.
ongoing 1970 c 10 lwb
1994 z-28 few mods.-owned since new
1978 vette silver/grey 25th anniv. paint
chevybill is offline   Reply With Quote
Old 08-01-2006, 03:08 PM   #2
chevybill
chevybill's Avatar
Re: People with gringoloco gauge setups.
nobody has this 3 gauge setup?
Old 08-01-2006, 03:28 PM   #3
Putter
More Cowbell....
Putter's Avatar
Good one.....got me thinking. You might do something like I did on Hart_Rod's. I drilled three 1/16th inch holes in his where the black meets the chrome between the top two screws and inserted three fiber optic indicators in there. You could have two outer ones green, and a center one blue or red for high-beam.
Bright as crap, too, so you would see them in the sunlight.
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket
Putter is offline   Reply With Quote
Old 08-01-2006, 06:18 PM   #4
chevybill
chevybill's Avatar
I was hoping you would see this. I plan on using some type of aftermarket wiring harness (painless or ron francis etc.) How much of a challenge will the wiring present? Did you use a regular drill bit or a small hole saw?
Thanks again, Putter and you have a PM.
Old 08-01-2006, 06:43 PM   #5
cstanley
cstanley's Avatar
i once fantasized about a 3 hole cluster...gringoloco photochopped what i was asking for, with the speedo and tach in the big holes, with the quad gauge in the middle. thread here: http://67-72chevytrucks.com/vboard/s...d.php?t=201368 pic below.
to answer your q, you'd have to do something on your own. i've seen them inserted into the gauges (high beam) in the original location. you could also do the brake/gen lights as well.
"Anybody who would paint his truck like this, would go to a minister's funeral dressed in feathers!" - Big Enis Burdett
'72 Blazer Restoration Blog: http://sportchicken.blogspot.com/
cstanley is offline   Reply With Quote
Old 08-01-2006, 07:41 PM   #6
chevybill
chevybill's Avatar
thanks cs stanley, i have not even considered the brake warning lights.
anybody know of a generic panel of lights i could get for this?
perhaps something from the street rod side of things?
