07-31-2006, 11:29 PM | #1 |
72 Blazer chassis 4x4 for sale or pieces I need
I got 72 blazer 4x4 chassis for parts for a project. I really only need the front set of brackets as I'm trying to get parts for a 4x4 conversion on a 2 wd.
Now before I carve this frame up I thought I'd ask if anyone wants this as it is in exchange for the brackets and some coinage. The frame is a 72 blazer 4x4 frame...the windshield frame has been cut off..so its a tub with the rear diff still in tact. 72 V8 vin still there also. The transfer case and engine cradle have been removed. It's basically a 4x4 frame and rear diff. Thought I'd ask before its carved up...and if its carved,,well theres some brackets off the rear diff I guess I could sell..yes there's one carpet strip from the back and the mounts for side panels in the rear. Jack spring and mounting brackets. I'd let it all go for $250 and the brackets I need..or I'll use this chassis and sell off what I can.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 07-31-2006 at 11:31 PM. |
08-02-2006, 08:29 PM | #2 |
Re: 72 Blazer chassis 4x4 for sale or pieces I need
Make an offer if one comes to mind.
08-02-2006, 09:37 PM | #3 |
do you have the rear upper shock brackets?
08-03-2006, 11:42 PM | #4 |
There on there for now...if I carve the frame up I'll let you know.
08-14-2006, 10:23 PM | #5 |
You mentioned a carpet strip, still have it? How's it look?
I could really use a good set of rear bumper brackets, so doofus stick-welded mine to the frame rails and I will surely ruin them when I cut them back off. I need all 4.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
08-14-2006, 11:31 PM | #6 |
This one still has the curved rear frame horns ..so no brackets...bumper bolted to the frame.
I still havent carved it yet..I may go look at it this weekend coming....I left it at a friends place for a bit. |
08-15-2006, 07:34 AM | #7 |
What kind of shape are the bucket seat mounts in. ( The ones that are spot welded under the tub )
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
08-15-2006, 08:30 AM | #8 |
This tub has had the windshield frame firewall back to the rear floor removed and sold by PO.
