Old 08-01-2006, 05:42 PM   #1
kingsolver72
10/30/19
kingsolver72's Avatar
Verifing engine #
I have a 327 engine,that is what I was told anyway.Can someone verify the #s for me.The numbers are 3956618.Thanks
Fight the good fight, finish the race, keep the faith
kingsolver72 is offline   Reply With Quote
Old 08-01-2006, 05:47 PM   #2
ratrod67
ratrod67's Avatar
Re: Verifing engine #
According to mortec.com
3956618....350.....69....2 or 4 Bolt main
ratrod67 is offline   Reply With Quote
Old 08-01-2006, 05:50 PM   #3
jhow66
jhow66's Avatar
3956618=
1968-69--302--290HP--4bolt main
1968-69--327--250hp,300hp,350hp--2bolt main
1968-79--350--250hp,255hp,350hp--2or4bolt main
Need # off front pad to see which one.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-01-2006, 07:04 PM   #4
kingsolver72
10/30/19
I don't know what you mean by the term,front pad.Above the # it looks like this:
20 GM
3956618
I did pull it from a 68 1/2 ton.
Old 08-01-2006, 07:14 PM   #5
John Fabris
TOTY 2006
John Fabris's Avatar
Looking at the front of the engine, on the passenger side of the engine where the bottom of the head meets the block, should be a flat machined surface that will have some numbers and letters stamped into it. If you can find that, it will narrow down exactly what the engine is and what it was in from the factory BUT that is assuming that the engine has not been decked as that would remove the stamped numbers. Also, are the heads on it, if so, pull the valve covers and ge the numbers off the heads as that may help as well...
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-01-2006, 07:37 PM   #6
kingsolver72
10/30/19
O.K. it looks like the # on the front pad is VO218FB.Thanks everyone.
Old 08-01-2006, 08:50 PM   #7
John Fabris
TOTY 2006
The engine suffix FB indicates that it is a 1969 327 from a full size car.
This info was from www.nastyz28.com....
John Fabris
67 C10 SWB
Old 08-01-2006, 09:49 PM   #8
kingsolver72
10/30/19
Thanks again John.
