Old 08-01-2006, 07:47 PM   #1
epthree04
epthree04's Avatar
quick heater hose question
i was replacing my heater hoses and the peice to my heater box that lets you connect the uper heater box hose broke. can i just route the heater hose from the water pump to the manifold? isnt that where the coolant ends up going anyway??
epthree04 is offline   Reply With Quote
Old 08-01-2006, 07:56 PM   #2
Sweet72
Sweet72's Avatar
Re: quick heater hose question
Yep, just bypass the heater core for now if you need your truck for transportation.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 08-01-2006, 08:01 PM   #3
epthree04
epthree04's Avatar
sweet, i knew that it would be okay but i really need it now bc the monsoons have messed the roads up here in tucson! no need to rush things! thanks!
