Old 08-01-2006, 07:52 PM   #1
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Got Bags???
**updated! Fully bagged pics are in thread**
Well, thought I'd share the progress of my '67. The rear is bagged and we'll be doing the front this weekend. I've got a few fittings to re-plumb. Found the leaks tonight, shouldn't be hard to fix them. I just need to find that Loctite thread sealer. Local Pep-Boys doesn't stock. Here's the pics, enjoy!
pic of the bag at full lift
pic of truck at full lift in rear
aired out:
I still have some room out back to go lower, as I've only got 1-1/2 blocks. I'm gonna get some 2" blocks and bury the rear another 1/2".
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 08-01-2006, 10:39 PM   #2
laidout86
Re: Got Bags???
hey man looks great u gonna be bringin it out sat night to the drag session?
laidout86 is offline   Reply With Quote
Old 08-02-2006, 09:01 AM   #3
bagged69c10
soon to be bagged64sub
bagged69c10's Avatar
Re: Got Bags???
Looks bad ass, wish I was in OT Florida. Suicide doors carries that loctite if nowhere locally has it.
1969 c-10, bagged, Zd, 20" Boyds SOLD!
1964 Suburban COMING SOON Build threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=304726
1965 c-10 long bed
1993 Sierra x-cab
1999 tahoe-4/5 on 22s
2005 Chevy work truck
bagged69c10 is offline   Reply With Quote
Old 08-02-2006, 09:20 AM   #4
Alvin
Never Done?
Alvin's Avatar
Re: Got Bags???
Looks great! I've got a couple questions for ya. How bad was it to drill the hole for the air fitting for the bag? I was bummed to see that I would have to drill a big hole through that c-notch plate! Also, what size tires are you running on the back? Looks like we'll basically have the same setup (c-notch, bags, 2" blocks), except mine won't be back together until late winter/early spring. Just trying to get an idea of where mine will sit. Oh, what about the bed floor? any issue there yet?
Ethel - The Legend Continues...
Ethel has been sold.
Alvin is offline   Reply With Quote
Old 08-02-2006, 08:06 PM   #5
PBFAB.COM
PBFAB.COM's Avatar
Re: Got Bags???
Truck is looking awesome! Keep us up to date with pics of the front bag install.
PBFAB.COM is offline   Reply With Quote
Old 08-02-2006, 08:42 PM   #6
TravisH
TravisH's Avatar
Re: Got Bags???
I just used blue loctite on my fittings, you can get it anywhere
TravisH is offline   Reply With Quote
Old 08-02-2006, 11:32 PM   #7
67Fleet
67Fleet's Avatar
Re: Got Bags???
I'll most likely be there. Gonna do my best. I won't be draggin it though. I'll watch.....
-Bret
Old 08-02-2006, 11:42 PM   #8
67Fleet
67Fleet's Avatar
Re: Got Bags???
Let's just say the air fitting holes need to be 1" diameter. Drilling through the notch + spring plate + frame + frame brace = 3/4" thick metal. It was the worst part of the whole process. I would have paid $200 to rent a plasma cutter for the day. Drilling the port holes was an absolute PITA.
-Bret
Old 08-03-2006, 12:43 AM   #9
bagged74
its just $$$$$
bagged74's Avatar
Re: Got Bags???
looks sweeeet...cant wait to see the front done.
bagged74 is offline   Reply With Quote
Old 08-03-2006, 08:08 AM   #10
Alvin
Never Done?
Alvin's Avatar
Re: Got Bags???
Sounds great! Maybe I'll spend half my weekend working on those.
Old 08-03-2006, 06:50 PM   #11
SCOTI
SCOTI's Avatar
Re: Got Bags???
Or...... you could just flip the bag & the air fitting is now @ the trailing arm which is muuuuuuuuuuch easier to drill through. It worked for me.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 08-04-2006, 12:23 AM   #12
67Fleet
67Fleet's Avatar
Re: Got Bags???
??? How? My Slams don't have a center mounting hole in the top of the bag, so I wouldn't have anywhere to put the 3/8x4 bolt. They only have 2 holes about an inch off center if I remember correctly, plus the port.
-Bret
Old 08-04-2006, 09:22 AM   #13
SCOTI
SCOTI's Avatar
Re: Got Bags???
You rotate the bag so the 'bolts' are centered in each half of the trailing arm. I drilled the mounting holes within a 1/4" of the center seam & drilled a hole for the air fitting/lines. My bolts also go through both the top & bottom of the trailing arm.
FWIW, some newer Firestones are set up for single bolt installations on top & bottom..... others could have a similar arrangement & I welded the seams of my trailing arms w/a 2" bead every 6" or so the length of the arms.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-04-2006, 06:21 PM   #14
67Fleet
67Fleet's Avatar
Re: Got Bags???
Wow, that's a great idea SCOTI. Wish I did a little more "thinking outside the box" on that. Hopefully it will save someone else some time and aggravation. I'm happy with the outcome of mine, and it's a super clean install the way I chose, it was just a total PITA. The fitting out of the bag is a MPT by quick-connect 90 ell, and then I'm running the airline straight down the frame-rail so everything is hidden.
With the bag flipped the airline will be running up the trailing arm, no? Do you have any pics of your setup? I'm interested in seeing how the line is ran.
-Bret
Old 08-08-2006, 10:41 AM   #15
bagged74
its just $$$$$
bagged74's Avatar
Re: Got Bags???
So did you get the front done or what??? I need pics, that truck is gonna be sick
Old 08-08-2006, 10:51 AM   #16
bagged69c10
Re: Got Bags???
Where did you get the kit from?
1965 c-10 long bed
1993 Sierra x-cab
Old 08-13-2006, 08:41 PM   #17
67Fleet
67Fleet's Avatar
Re: Got Bags???
Front's done!!!!
Mad lift!!
Dumped:
I should have got some pics hitting sides, but it looked like another storm was going to roll in so I put it back in the garage. Man it rides nice!!
Now the only thing left is to install my 2nd Viair 380c compressor. The front really drains the tanks raising it up.
-Bret
Old 08-13-2006, 08:43 PM   #18
bagged69c10
Re: Got Bags???
So Where Did You Buy The Stuff To Do The Back?
1965 c-10 long bed
1993 Sierra x-cab
Old 08-13-2006, 08:56 PM   #19
67Fleet
67Fleet's Avatar
Re: Got Bags???
suicide doors. I got everything from them.
-Bret
Old 08-15-2006, 07:36 PM   #20
Bushmaster
Junior Member
Re: Got Bags???
Can you post some pics on how you did your front? Looks good
If You Can't Spark It Park It...
Bushmaster is offline   Reply With Quote
Old 08-15-2006, 09:26 PM   #21
SCOTI
SCOTI's Avatar
Re: Got Bags???
Looks great.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 08-16-2006, 10:34 PM   #22
67Fleet
67Fleet's Avatar
Re: Got Bags???
I don't have any pics yet as we were so busy trying to get it done that I forgot to take pics. Basically I'm running the standard upper plates from S.D., lower cups that were cut down to 1" height, Slam RE7 bags, and 4 valves for the front, 2 fills/2 dumps. The valves are mounted behind the front bumper on the bottom of the core support. I need to get you guys some pics of the custom gauge plate I made from scratch. I'll try and post that tomorrow night. It came out looking killer.
-Bret
Old 08-16-2006, 11:10 PM   #23
68 short step
Re: Got Bags???
great truck
68 short step is offline   Reply With Quote
Old 08-16-2006, 11:11 PM   #24
slammd72
slammd72's Avatar
Re: Got Bags???
looks awesome!
88 shortbed crewcab
currently getting a sfbd 4 1/4"
slammd72 is offline   Reply With Quote
Old 08-17-2006, 01:31 AM   #25
sixty8c10
MY EX DRIVES A BROOM
sixty8c10's Avatar
Re: Got Bags???
badazz
They say nobody's perfect.
I'm a nobody, so I must be perfect.
Building Nemo -1968 C10 Long Bed
FRED -1947 KB-2 International
sixty8c10 is offline   Reply With Quote
