Old 08-02-2006, 01:43 PM   #1
kansas city cheyenne
Rebuilding 1 at a time
kansas city cheyenne's Avatar
Electrical question
I am having a problem with my turn signals. They were working fine but now they flash about 5 times too fast. I have replaced all the bulbs and that still didn't fix it. But all the other lights work fine, headlights, break lights etc. Any suggestions?
71 cheyenne lwb
383 stroker
2004R tranny
Factory ps, pb, air
http://smg.photobucket.com/albums/v3...t=101_0059.jpg
66 Nova SS L-79
327
m21
http://smg.photobucket.com/albums/v3...t=101_0042.jpg
kansas city cheyenne is offline   Reply With Quote
Old 08-02-2006, 02:34 PM   #2
dallas71
dallas71's Avatar
Re: Electrical question
I have seen this before if you have a HD flasher in it.....other than that no clue....
dallas71 is offline   Reply With Quote
Old 08-02-2006, 03:21 PM   #3
bryanw1968
bryanw1968's Avatar
I agree. Sounds like the flasher.
bryanw1968 is offline   Reply With Quote
Old 08-02-2006, 09:13 PM   #4
ChevyCrazy67
ChevyCrazy67's Avatar
flasher relay
Kevin
1967 C-10 swb fleetside
1968 C-10 stepside
1999 Z71- sons dd
1999 2wd silverado-my dd
2003 Tahoe- wifes dd
ChevyCrazy67 is offline   Reply With Quote
Old 08-03-2006, 10:20 AM   #5
67chevy2wd
67chevy2wd's Avatar
Wouldn't a HD flasher cause it to flash slower? There is something draw too much current and causing the flasher to flash to much. I know some people would put the HD flashers in because when they hooked up a trailer the trailer blinker lights would draw too much current for the smaller flasher and cause them to flash way too fast. The HD flasher would cure this because the bi-metal strip in the flasher was heavier.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 08-03-2006, 05:38 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
you are correct, the HD ones would go agonizingly slow.
Quick troubleshooting tip, swap the two flashers around. You have one for the turn signals, and one for the 4 ways. if you swap and they work properly, replace the flasher. If it still actsd stupid, then something is wrong, and what ever it is, it is placing a huge load on the flasher. It would just about have to be a messed up turn signal switch since it is doing it on both left and right.
