08-02-2006, 01:47 PM | #1 |
Active Member
GM crate HT383 or ZZ383
Does anyone on this board have either of these GM PP crate engines in their 67-72 trucks?
Just looking for anyone who's had experience with thiem. Thanks
71 Blazer CST 72 K20 Capt USAF |
08-02-2006, 01:55 PM | #2 |
Re: GM crate HT383 or ZZ383
Nope, but I think you could build either one, better and cheaper. They sell 383 kits cheap, balanced and ready to drop in. Only if I had the spare coin would I do it because a warrantee is nice. The ZZ383 is supposed to be badazz, the other is an entry level iron headed 383.
08-03-2006, 06:36 AM | #3 |
Is the "ZZ" the fast-burn 383?Those have some quality components in the rotating assembly like forged rods,steel crank...but,it`ll cost you.Well worth it,though.
08-03-2006, 08:30 AM | #4 |
Buddy of mine has a brand new ZZ4 in his 63. Not sure what (other than displacement) difference is between the 350 an 383 models, but he loves his.
Another friend had told me he installed several of those in various cars when he worked for a speed shop and he was very surprised at how well they performed. (He was a 600hp Nova so he's fairly experienced with quick cars). I'm sure that both of them would be good, I know the specs on the HT383 cam are slightly more tame, and I'm sure it's cheaper since it comes with the Vortec heads instead of the fast burns. |
08-03-2006, 08:37 AM | #5 | |
Happy to be here
I'm not sure why you want a 383 but those have proven to be good motors. Best bang for the buck is the fast burn 385....
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 08-03-2006 at 08:37 AM. |
08-03-2006, 09:37 AM | #6 |
Active Member
I think I want the 383 because of the low end torque. I never top out the motor and hardly get it above 4000 RPM. I want something that will cruise on the highway up a hill with a load without losing and oomph, if that makes any sense. The HT383 is appealing because it runs on 87 octane and the ZZ383 requires 91. Looking to mate whatever I get with an NV4500 to replace my SM465. I need one more gear to cruise on the highway.
08-03-2006, 10:19 AM | #7 |
Questionable
ZZ4 is a great engine. My uncle builds race cars (and races religiously) in Vegas. He swears by the ZZ4's if you want something that has "Balls right out of the box" and is also capable of huge buildups straight out of the crate.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
08-03-2006, 02:20 PM | #8 | |
Most of the decent crate stuff I've seen is right around this price range...the cheaper ones are cast cranks. You could probably build an all-cast 383 for around 3K assuming a good used block and Vortech heads and this would be fine for your application IMHO. There are cheaper 383 long-block packages out there, but if you have the ca$h these are a rock-solid engine. |
08-03-2006, 02:38 PM | #9 |
Actually a brand new 350 block from GM is the same or less than a used engine after a full machine shop workover from what I can tell. Less than $700...it's quick surprising.
08-03-2006, 06:07 PM | #10 |
I am a Referee of life.
I looked at some specs some time ago on the crate 383.It comes with enough pan rail clearance for the stroke and hasn't been overbored.This would be a plus for an engine you planned on having long enough to need a rebuild.The warranty would also be a factor as would the tech support.If you were to build a 383 you would have about as much in parts as this engine costs for equal stuff(forged crank ect).Also if you don't use a complete stroker kit you may have problems with mismatched parts.
I think I would go with the iron heads for a truck.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
08-04-2006, 06:36 AM | #11 |
I built my 383 for $1,500.I wanted a budget motor and I got one.The crate motors are greater than the sum of it`s parts when it comes to dollars and cents.The best bang for the buck,for sure.But,they wouldn`t sell me 1/3 of an engine and it wouldn`t have got me done the road,anyway.
08-04-2006, 12:17 PM | #12 | |
08-04-2006, 12:43 PM | #13 | |
Completely agree that doing a 383 is very cheap if you look at it as part of an O/H, especially if the crank is beyond salvage. Biggest expense is typically the heads, as a low-end heads aren't well matched to the "deep breathing" of a 383. A marginal head that isn't that big of a deal on a 350 will seriously choke a 383. |
08-04-2006, 12:51 PM | #14 | |
I reused the heads that were on the 350 that I replaced. They had a valve job done less than 10,000 earlier. I'm firmly in the camp that says if you are rebuilding your 350, why not make it a 383 for less than $100 more.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
08-04-2006, 12:53 PM | #15 |
You can get a balanced stroker kit with cast crank and pistons from POWERHOUSE in CA for about $400. A used set of Vortecs can be bought and redone, or $500 new, plus machine work on the block and you are at the $1500 range, folks it can be done and unless you lay on the motor 6500 RPM everywhere you go a forged crank is overkill. I saw a buildup in HOTROD or CARCRAFT using a powerhouse kit and they had their machine shop verify the balance job and it was dead on from powerhouse. So the way I see it you can build to 383's for the cost of the ht383. and probably 3 of em' for the cost of the ZZ383.
08-05-2006, 12:26 AM | #16 |
I have the HD 383 in my truck and don't have any complaints. When I was doing my research, there was an article on the 383 crate engines, 50 hrs continuous running w/ oil changes every hour and I think they ran it at 5000 rpm's. After the test they tore the engine down w/ virtually no engine wear and no stretching of the connecting rod bolts....
www.cardomain.com/id/pooz911 |
08-05-2006, 07:45 AM | #17 |
I bought a 383 rotating assembly(internal/10:1),cam/lifters,dbl.roller,hi-vol.pump,roller tips,and gaskets.Had the machining done including some flow work on the 365hp heads(327).I have seat-of-the-pants dyno results @ 400+/-.I already had the motor/heads,it was a rebuild and I wanted cheap and I got it.More is better,but it`s more.Alot of options out there.
08-05-2006, 09:44 AM | #18 |
Not to throw a wrench in everyone's train of thought, but the engine builder in the following link has some strong opinions on crate motors. He seems knowledgable and enthusiastic, but of course, crate motors would be (what I think) the number one threat to his livelihood. Crate motor business is money right out of his pocket I would think. I'm not an engine builder or an auto expert so I'm not sure how much of what he publishes on his website is valid, but he does have some good info. I bring up his website because I was doing research on both sides of the crate motor vs. custom-built engine argument and I want to get as much info to make an informed decision before I drop $$$$ into an engine. AJ
http://www.badasscars.com/index.html
72 Chevy 2wd lwb 350/TH350 72 Chevy 4wd lwb 454/TH350 |
08-05-2006, 09:50 AM | #19 | |
Keep in mind that this question included having a shop do all the work - I'm assuming you guys that did it for $1500 did all the final ass'y yourself and just farmed out the machine work. If you add in the shop doing final, I'm not sure the numbers would be ALL that different between a crate and rebuild. Lots of good advice here - I wonder if we could summarize as a sticky. I just went through this whole debate with my 1995 LT1, but had to stick with the stock crank as SCCA Street Modified requires < 6.1L |
08-05-2006, 10:14 AM | #20 | |
08-05-2006, 11:47 AM | #21 | |
I got the assembled short block back from the guy. I bolted my heads, oil pan, and an old intake on it. I then sprayed it chevy orange. After that dried I put my new Edelbrock intake on and dropped it in the truck. In the truck I put on a new Edelbrock 1406 carb. The list below does NOT include the new carb and intake. Most guys aren't taking out a 2bbl 350 like I was so this may or may not be an added cost for you. Here is the breakdown on what I did (I have posted this before)... 383 related parts & labor: Crankshaft.............................200 400 Balancer (used)..................30 Balance job............................200 Cut con rods for cam clearance.........................20 400 flywheel.............................30 clearance block for con rod clearance............................15 ARP con rod bolts.......................38 Oil pump drive..............................8 Oil pump sump..............................9 Performance engine Kit: Sealed power moly rings, Fel pro gaskets, con rod bearings, main bearings, cam bearings, block plugs, 383 pistons, three piece timing set, oil pump....................317 R&R block plugs..........................10 degrease block...........................35 deck block.................................50 bore & deck-plate hone cyl(s).......80 deck-plate charge.......................10 Remove, install, & fit cam bearings..25 Recon con rods...........................80 Pin fit new pistons.......................28 Assemble short block....................75 Sales tax....................................26.13 Total ===>.............................$1286.13
08-05-2006, 09:11 PM | #22 |
A couple responses:
*Why pay someone to do work you can do?Don`t we all want to claim as much credit for our trucks as we can?And,what`s wrong with saving money? *Part of the weighing process for me is,do I already have a motor to build?If I needed everything,the crate just got cheaper. *Cast cranks are in one of the "crates" in discussion,right?The HT383 has cast.(Oops,wrong) *My 383 has 40 year old $75 factory performance heads,not Vortec or Aluminum.Like I said twice the first time,I was building a good motor for cheap.It`s not a competition vehicleor a daily driver.This motor is extremely cost effective.It will prolly take me 10 years to put 20,000 miles on it. *I want a ZZ383,too.But,I really like my custom home-built 383 and so does everybody else. *GMPP has more R&D money than any other auto industry supplier in the world,I`d think.Plus it`s GM modifying their own motors.They could be considered experts.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 08-06-2006 at 07:20 AM. |
08-05-2006, 10:38 PM | #23 | |
The ZZ4, ZZ383 and FB 385 all have forged cranks, PM rods and PM pistons. |
08-05-2006, 11:25 PM | #24 |
Active Member
According to the GM PP catalogue, the HT383 has a forged steel crankshaft, same as the ZZ383, so niether of them are cast.
08-06-2006, 07:18 AM | #25 |
Ok,I was going from memory(not an accurate one apparently ).My responses aren`t necessarily to questions,but to info and comments mentioned.Just adding some balance .
