5-speed manual options ... ???
Does anyone know what 5-speed manuals (stock or otherwise) bolt up to our older V8's? I'm really interested in finding something that would allow me to cruise @ 2000-2200 rpm while on the highway.
If anyone has experience or info to share, that would be greatly appreciated. Thanks, Dave |
Re: 5-speed manual options ... ???
Sorry, I have a '68 C-10 with what looks to be the original 327 in it ...
A V8 is a V* SBC or BBC and the years pretty much too. I'd say a great way for major power is a TKO 500 or 600, if stock you could get away with a 5 or 6 out of a camaro of the mid to late 90's or if heavy duty truckin' NV4500. the TKO's are in the $2-3K complete ready to bolt in and the used 5's out of Camaro's can be had for $1k or so, NV4500 about $1500-2000 just for the tranny.
Great info!!!
I'm looking for something that could utilize the same ... or relatively the same ... stick position and orientation. Truck will not necessarily be used for racing or need "quick throws" ... mainly a "daily driver"/"work truck" scenario ... but could have fun with when necessary. What about the stock manual trannys out of newer model Chevy trucks, once again due to the needed stick position and orientation? Thanks again, Dave |
You do not want a 5 speed from a 80's Camaro. The Camaro / Mustang's used the T5. It is a good reliable transmission.. behind a 4 banger or maybe a 6. The best T5's were only rated to 300ft lb & still wouldn't last too long at that.
I'd have to agree about the NV4500 being a good solid choice. The NV3500 would probably be cheaper & work too, but not take as much abuse.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Hes talking a 327 and the 5-speeds out of the later camaros were behind 350?'s I forgot about the NV3500, they are good for what you want.
Senior Moment
![]() Join Date: Mar 2002
One thing to watch for is if the front bearing retainer fits firmly into the bell houseing so your lined up straight. The muncie retainer is smaller than the B houseing and a ring needs to be made to make up the differance
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
So the NV3500's are a strong transmission. How well would it hold up behind a stock 350 with flat tops and a mild cam? If I could pick one up for a couple hundred bucks is that a good deal?
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
The NV 3500 came in manual truck in the 88-98 series trucks. I have a 92 with this tranny and it has been a good one (268,000 miles and counting).
For street trucks with only slightly modified engines they are fine, unless you plan on driving one quarter of a mile at a time. I am using one in my 70 c 10. Some 4.3 liter v 6 s 10 trucks have this same transmission. I am using my original driveshaft with this tranny and the engine in the forward position. The greatest challenge is the hydraulic clutch setup, due to the tranny having an integral bellhousing. Do a search and you should find several thread about this topic.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
its all about the +6 inches
the T-5 was NEVER installed in front of anything bigger than a 305. Not from the factory. Ford 302 and Chevy's dog of a 305 kills T-5 trannys.
MAYBE a 327 wouldn't kill it... but, the part where he says "Use it like a truck" probably would. You may get 50 - 75,000 miles, but that's it, and only if it is a solid new or newish tranny to begin with. A 283, or any inline, would be great to bolt up to a T-5. |
Chevybill, what transmission X-member are you using in your C-10? When it comes to the integral bellhousing, you just had to install a clutch master cylinder? If so, what and how did you do it? Pics would be great, if you have or can take any ...
Thanks, Dave |
#12 | |
I'm trying to get down to 2000-2200 rpm too. I use a 4 speed muncie and now I'm playing with the rear gears. 3:73 are still too high. I just bought some 3:07's so I'm let you know it it works.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
#13 | |
Are you sure you want to get down to the 2000-2200 range? Someone was on here just the other day getting poor mileage b/c he was lugging his engine on the interstate at these speeds.
Just a thought. Quote:
#14 |
Will the trans out of a 4x4 work in a 2wd? In theory shouldn't you get better gas mileage while slightly lugging your engine? You would be dumping in the same amount of fuel but the engine would be turning slower giveing the fuel more time to burn. Just a thought, correct me if I am wrong.
#15 | |
This transmission can use an aftermarket x-member and auto tranny mount on the crossmember. I do not have my pedal setup figured out just yet. I have no pics. I will be mounting a master cylinder on the firewall. The main part is getting the pedal movement correct without "bottoming out" the master cylinder. The easiest way to do this is to purchase an entire truck with this tranny, pedal, etc all still intact. I did not have that advantage and am piecing things together as money permits.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() Last edited by chevybill; 08-03-2006 at 02:42 PM. |
#16 |
Ive heard over on chevelles.com that they are working on a 5 speed muncie. Youd have to buy the entire trans or gearset and swap it into your trans. However not sure if the truck muncie and car munie have the same cases...etc
