KEEP ON TRUCKING
rearend eaton ho52 help
how much grease do they hold its the eaton h052.
we had to put 6qts in it one time but it i dont think it was empty then were putting it back together and cant get the fill plug out.so were going to install one axle and then jack the othe side up and pour grease thru axle tube.
72 cheyenne 2wd lwb 71 k20 sons bassett va |
![]() Join Date: Jul 2006
Re: rearend eaton ho52 help
So you're talking about filling up a eaton posi rear end right?
I have a 12 bolt eaton posi 3.73 and it required 2 1/2 to 3 quarts of 85/90 weight gear oil. 6 sounds like a lot unless I'm missing something. Good luck, B |
KEEP ON TRUCKING
this is actuallay a eaton rear 3/4 ton 4x4 rear this thing is huge
This rear is a full floating axle and has the big round 10 bolt cover, almost looks like a big truck axle. I don't know exactly how much it holds, but the easy way to know when it's full is to put gear oil in it till the level is just below the fill plug hole. Now since the plug is stuck I don't think that method will work.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
Cantankerous Geezer
6 pints for an eaton 10 bolt. Another way to fill is to remove a cover bolt at the same level as the drain plug. You can squirt warm oil in that way. Put the bolt back in with sealant.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
KEEP ON TRUCKING
thanks
Fred hit the nail on the head.What I`ve done in your situation is,put 6qts in the axle tube,then remove the cover bolt at the plug-line to let extra lube out.It`s just a bit quicker.
I gotta stay outta these 4x4 3/4 ton threads!
hehehehehehehehe |
Same rear in 20 series 2wd.
speciak k why do you use twice as much lube as fred? then drain it back out
common sense isn't so common anymore |
OOps...I meant pts,not qts...misprint,good eye.I was giving an easier way,but the "same" idea.
