Water pump/temp sending unit
Can I put my temperature sending unit in the plug on the top of my water pump?
It would save me from having to buy a new water neck b/c the one I have makes the radiator hose rub down on the temp sending unit when it is mounted on the intake.
68 Chevy 383/350 w/shift kit, 380hp/425ft-lbs, 4.5/5 drop, 17" TT2s 64 Cadillac Sedan DeVille |
Re: Water pump/temp sending unit
Mount it in the head where they normaly are.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
The problem is my intake only has 2 holes. The one on the passenger side is for my heater hose, and the one on the driver side is right in the way of the radiator hose, the sender rubs a cut into the rad hose unless I can find or order in a new taller water neck.
If it wasnt a problem, I would put it in the normal place, just seeing if its ok for me to take this shortcut.
plug one side of the intake with a brass fitting
put the sending unit in the head like posted earlier this is the most effective and cost efficient solution to the problem |
Problem with the pump is the sender might get in the way of the pump vane.
Ok, mine was never mounted in the head, it was always on the intake so I assumed this was where they normally were. I guess there should be a plugged hole in my heads? I have Edelbrock Performer RPMs.
This should show you where it is:
http://www.edelbrock.com/automotive_...t_sb_rpm.shtml
TOTY 2006
![]() Join Date: Dec 1999
I have seen several engines (one being my buddies 67 chevy truck) where the temp sending unit is mounted in the top port of the waterpump. It will work, just check that the pump spins freely after tightening the sending unit..
Ok. It did spin freely, but I think Ill take it off the pump and put it on the head, get it out of the way a little bit too.
