Old 08-03-2006, 01:57 PM   #1
scotto0609
Junior Member
Help! wiring question.
I am hooking up an older holley projection unit on to my 85 k30,the instructions tell me to connect pink wire to "the starter solenoid terminal that is energized during cranking of the starter motor". Anybody know which one that is? thanx
scotto0609 is offline   Reply With Quote
Old 08-03-2006, 06:30 PM   #2
magnethead
7000 #'s of american IRON
magnethead's Avatar
Re: Help! wiring question.
that means connect it to the starter solenoid output (starter side) i'm guessing??
magnethead is offline   Reply With Quote
Old 08-03-2006, 07:56 PM   #3
CN84C10
If you look at the two wires connected to the starter. There will be a big and small one. The smaller one will be purple. Trace it from the starter to a closer spot in the eng. compartment and tap into it. Hope this helps.
84 C10 Vortec 350, Turbo350, 12 Bolt w/3:73
14.42ET
Soon to come 150 Shot
CN84C10 is offline   Reply With Quote
