NEED HELP.... FAST!!! (ENGINE SWAP ???'s)
I have an opportunity to get me a LT1 from a 95 impala and i want to put it in my 84 chevy swb. The only thing is that I dont really know if it will fit or what I have to do to make the conversion. Truck currently has a stock 305 in it so maybe that will help some of you that have more of a mechanical brain than me. Help me figure this thing out cause i dont want to lose that motor to someone else. Any help would be appreciated.
Reply asap or call me with some helpful info at 469-569-3204 |
Insert Witty Text Here
Re: NEED HELP.... FAST!!! (ENGINE SWAP ???'s)
I would do a search. It has been covered pretty well in the past. I don't know details. I'm still stuck in the 80s.
![]() Slonaker |
#3 | |
The motor inself will bolt right in just like your 305. BUT you will need a ecm and wireing harness for the motor, and also don't forget that these engines have a reverse flow cooling system. It would be a nice engine in one of these trucks. |
#4 | |
thanks bigchevyman, The motor will come with the computer and everything else from top to bottom but dont know if it will come with the harness. Wouldnt the reverse flow cooling system be already in it if its all complete? |
#5 | |
#6 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
GET THE HARNESS WITH THE MOTOR!! Along with the computer and the radiator. You really don't want to skip the harness, it could cost you from $400-900 for a stand alone harness. Pulling the wires you don't want out is much easier than buying a computer AND a harness for it. Plus the weatherpack plugs are EXPENSIVE!
If it were me, I would get from the radiator to the driveshaft and I would get the manifolds down to the Cats. AND I would get EVERYTHING the harness connects to for the engine. Anything you don't use LABEL it.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
Sb 400 club
the cap got it man
some one on here did a similar swa for a eskalde motor i think goode luck
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
Slots go on anything!
You will need to move the right side engine mount back on the frame, and notch that side if you are going to use the A/C compressor. I would suggest using the fuel tank out of an '87, as it will have the baffles for EFI.
1974 Jimmy- 5.3/4L80e/NP241 |
needin' money
this might also help a little bit http://www.hotrodlane.cc/PDFFILES/83chevyLT1install.pdf
SWB Stands for Short Wide Bed |
#11 | |
My info is located here:
http://67-72chevytrucks.com/vboard/s...d.php?t=193657 OR Here: http://p210.ezboard.com/f7387chevytr...cID=2395.topic
#13 | |
![]() Yeah, I just bought an lt1 of a 93 formula, which I plan on installing on my 84. Does anyone know if I can bolt up a th350 to the lt1?
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265 |
#14 | |
7000 #'s of american IRON
#15 |
it will bolt up, but why? I would definitely go 4L60E.
#16 | |
