Old 08-03-2006, 09:48 PM   #1
indyracer
indyracer's Avatar
Wheels and tires, What to do...
When I get the '70 C10 home, one of the things that I want to change is wheels and tires. Please give me some ideas for front and back wheel sizes. I think that I am going to go with 16" wheels. I want the truck to have a nice stance. Nothing too narrow if you know what I mean. If you also have pics as examples that would be great.
Thanks,
Tony
Cheers,
Tony
A day without sunshine is like, you know, night.
1970 Chevy CST10 (Green)
2005 Silverado Z71
2000 Pontiac Bonneville
indyracer is offline   Reply With Quote
Old 08-03-2006, 10:44 PM   #2
Green Machine
Green Machine's Avatar
Re: Wheels and tires, What to do...
Check out this thread for some ideas -
http://67-72chevytrucks.com/vboard/s...d.php?t=143835
This is just a shot in the dark cause I don't know what look you are going for, lowered or what, but if stock height you can fill up the wheel wells nicely with a 245/75/16 on a 7 inch rim with about 3.5 to 4 inch backspacing, or a little wider but same height a 265/70/16 on a 8 inch rim with about 4 to 4.5 backspacing. Or run the 245/75 on front and the 265/70 on back. Those are common tire sizes that are cheaper too.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-04-2006, 07:15 AM   #3
indyracer
indyracer's Avatar
Thanks for the link to the thread. That is just the info I am looking for.
Tony
Cheers,
Tony
2005 Silverado Z71
Old 08-04-2006, 09:07 AM   #4
jamon8
jamon8's Avatar
I think these trucks look HOT with centerline autodrag looking wheels
My truck is in so many pieces and bieng stripped and etch coated but one day I may be able to show her off
jamon8 is offline   Reply With Quote
Old 08-04-2006, 03:32 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I am running Wheel Vintique wheels on mine...15x8 on front, with a 4-inch back space. Back has 15x10 with a 4.5-inch backspace. Front tires are 245-60's. Rears are 275-60's. Running hot rod trim rings and police car caps on the 'Vette-style rallye wheels. Summit Racing has 'em.....free shipping, too.
I found that running anything wider than a 7-inch wheel on my truck front end, was not good. I have ECE disc conversion and the 8's I had, with a 3.5 inch back space caused the wheels to move out too much. The backspace is the key, to good aesthetics.
Member Nr. 2770
Old 08-05-2006, 09:34 AM   #6
pkj
hey green machine, sounds like you know your numbers and maybe can help. 68 long fleet. i have 8.5x20 wheels with 5.5 bs tires are 275-55-20 aprox. 31 inch tall thinking about 3/5 drop. how far is my backspacing off front and rear? i cant mount wheels untill i machine out centers. i reilly am stuck on these wheels and tires. can you help?
pkj is offline   Reply With Quote
Old 08-05-2006, 01:18 PM   #7
Green Machine
Ok, depends what year you have, 5.5 is a lot of BS, but if you have front disks and the rear end is late 1970 thru 1972, they are about 3/4 inch wider front and back than the earlier all drum setup. If you have the wider axles you might be OK. There is a pic of a blue truck in the wheels/tiires thread above that has 17 inch Impala wheels 8.5 wide with 5.125 BS and I think it looks OK, but it might be stock height.
Old 08-06-2006, 11:35 AM   #8
pkj
thanks green machine. i have stock 68 drum/drum set-up. sounds like it wont work out with-out some changes. the tire size can still be changed since i have not mounted them yet. i cant mount the wheels untill i find out how far to machine the center bore out, nobody seems to know and i dont have access to the truck right now. if i find out the correct bs i will have 6 to 6 adapters made not spacers. i am set on 3/5 drop and these 20 in. 07 tahoe wheels. trying to get things ready before truck arrives. so thanks for any help.
