Old 08-04-2006, 12:42 AM   #1
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
will a 67 camaro sub frame
fit on a 70 chevy truck theres a camaro disk brake sub frame for sale for 250
i wanted to know if it will work on my 70 chevy truck anyone know ?
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 08-04-2006, 04:56 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: will a 67 camaro sub frame
No clue if it will or not, but I would think you'd be stressing the camar stuff.... including the small brakes.
Old 08-04-2006, 05:06 AM   #3
I`ve heard of people either doing it or wanting to do it.Ijust don`t know why.It`s not something I`d consider.These trucks already have a coil/a-arm suspension,only heavier,for a reason.If you`re looking for a swap to discs,any truck f/e assembly through`98 can be swapped,not grafted in.
Old 08-04-2006, 07:57 PM   #4
70gmcjimmy
GMCDAC
70gmcjimmy's Avatar
Never tried putting one of those stubs on a truck but have messed with em building dirt track stock cars. The 67 if I remember right is a "rear steer" which means the steering box and tie rods are behind the crossmember. That created many issues with clutch linkage and headers. I may be thinking of the Nova stub(but I think they were basically the same)-this was a long time ago. What I do remember is that when 70 and newer stubs started being more available, no one used those older ones anymore as they went to "front steer" and the room issues were solved for the most part.
I do agree with the other guys tho that just using truck disk setups and all is the way to go. It doesnt make any sense to me to hack off a stub, go thru all the fabrication to fit the Camaro one and in essence make no substantial improvements.
Later---DAC
1970 GMC K5 Jimmy Custom 4X4 Mom's driver from 1971 to 2001!! Under rebuild!
1972 GMC C2500 Pickup owned since 1979 Needs a rest and refurbish!
1955 GMC 100 2nd design driven almost daily!
Rest In Peace Mom. "Dolly" 7/15/23 - 5/18/09
GMC driver for 30 years!
70gmcjimmy is offline   Reply With Quote
