control arms needed?
hey guys whats goin on...i just recently put on my new rims/tires and it lifted the front end up..im runnin a 265/35/22 and was wondering if im gonna need tubular control arms to get the front to lay out..right now the crossmember is about 2 inchs or so off the ground..i want to get the crossmember laid out first so i dont have to make a bigger z than have too...thanks alot guys!
Seņor Member
Re: control arms needed?
Tubular control arms aren't going to give you any additional clearance.
soon to be bagged64sub
If you get plenty of lift I would check into cutting down the bottom cup a bit. Just make sure it wont rub if you cut it down. Im assuming you have spindles already and an upper plate, lower cup setup.
1969 c-10, bagged, Zd, 20" Boyds SOLD! 1964 Suburban COMING SOON ![]() 1965 c-10 long bed 1993 Sierra x-cab 1999 tahoe-4/5 on 22s 2005 Chevy work truck |
yea have that already and the bottom cup is cut down to 1 inch already
Sold! 2 days after finished
Take out the lower cup and weld a flat plate in the control arm. That might get you another inch.
Epoxy Primer Friendly
If the truck is an 86 you dont need a lower cup just bolt it to the LCA. They are big enough. Just make sure to debur it and clean it all up.
i just ordered lowers so as soon as i get them im gonna put them in and see if it helps....im gonna put them in without the cup also so.....
#8 | |
Junior Member
yea i got 3 inch drop spinedles on there with a suicidedoors upper plate with a slam re-82
