Garage Queen Material
brake upgrades?
any new and exciting products come out recently in the brake department?
after driving my mustang, and then driving the truck.... well, thats all i need to say. truck has stock brakes right now, what would be the best cost efficent route to go upgrading? If i wanted to upgrade to larger rotors and new more than 1 piston calipers, would i also need a new spindle? |
Gentleman Jim Driver
Re: brake upgrades?
I think you have two choices. This:
http://www.stainlesssteelbrakes.com/...D%29&year=1986 and this: Baer Part# 4301052 http://www.paceperformance.com/index...&ProdID=136538 Both are significantly expensive. I'd go with Baer if I were going to spend this money as I really don't like the lack of engineering SSBC puts into their products.
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
7000 #'s of american IRON
Re: brake upgrades?
its not a kit, but i think somebody make 6 piston front calipers and somebody else makes cross-drilled rotors.
#4 | |
Re: brake upgrades?
geeeeeeeeeeze!!!!!!! ![]() ![]()
1987 350 TBI lowered 5/7 |
Re: brake upgrades?
i'm thinking more like a simple dual piston calipers and larger rotors.
any thing that is under $1k? |
Re: brake upgrades?
LMC page 63
front cross drilled rotors (200 bucks per front set) not sure on calipers... |
Insert Witty Text Here
Re: brake upgrades?
If you have the light duty brakes like I do, you could go to the heavier ones. Of course, that requires a spindle change. Maybe consider rear discs like swervin installed?
Slonaker |
I'm back with 2nd truck!
Re: brake upgrades?
Eric didn't you install drop spindles? What rotor did you go back with then?
1979 Chevrolet Bonanza Big10 "Tootsie Roll" 1985 Chevrolet Silverado (wife's) Member of the Southern Bowties Club "Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson |
Re: brake upgrades?
I personally would prefer a 14" or larger rotor, it may seem small, but i have 16" dually rims, so I think that's what my truck has with 4 piston calipers and even with toasted rear brakes (i drove 5 miles the other day with e-brake floored) it still stops in a decent manner.
#10 | |
Re: brake upgrades?
No Life Like Low Life
Re: brake upgrades?
Here is what I'm running 14" cross drilled and slotted with 4 piston wilwood froged superlite. Precision brake company custom made the kit for major$$$$$
I have 6 pistons up front.
Eric 1978 Chevy Scottsdale 1960 Impala ZZ4 1965 Buick Riviera GS 2011 GMC Sierra Denali |
#12 | |
Re: brake upgrades?
just a reminder ![]() |
#13 |
Calibration Engineer
Re: brake upgrades?
i really like how the ssbc kits look, don't know anyone with them on these trucks but i know a ton of people running ssbc kits on older muscle cars.. not a single complaint..
i'm looking into getting the slotted rotors soon ($215 w/ pads..)
#14 |
Happy to be here
![]() Join Date: Mar 2000
Re: brake upgrades?
Eric the most "cost Efficient" way to upgarde your brakes is use a performance pad. Check withHawk Performancefor better pads or Praise Dyno for crygenic treated brake kits.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 08-07-2006 at 11:32 PM. |
#15 |
Re: brake upgrades?
man, i guess on our trucks, brakes are one thing that is more expensive than the mustang...
#16 |
Junior Member
Re: brake upgrades?
Eric,
I do not know much about your truck but here are a couple of things you might consider: >If your engine cannot reliably produce about 18 inches of vacuum then your booster is not working up to its potential - you might consider a backup vacuum pump. >If your engine vacuum is okay then you might consider installing a larger booster or a smaller bore master cylinder. >Not sure if it will work but you might consider changing the pedal pivot point(s) to the manual brake locations so that the pedal has more leverage. HTH,
Have fun, Don |
#17 | |
Re: brake upgrades?
#18 | |
![]() Join Date: Jul 2003
Re: brake upgrades?
