Old 08-05-2006, 01:54 AM   #1
magnethead
7000 #'s of american IRON
magnethead's Avatar
Repair panels?
I rang up total cost of what it would be to remove most of the body cancer from my truck. the only things that i can't account for is 4 Complete (as in everything but the trim) door units.
Front Fenders: LMC 25- (14) 79.95 each
Carpet: LMC 69- () 179.95
Dash Hardcover: LMC 75- () 99.95
Rocker Panel UNITS: LMC 24 (10) 19.95 each side
Cab Corners: LMC 24 (11) 14.95 each corner
Fiberglass Hood: Jegs 487-B45201 439.99
Now if I added that up right, it comes to 220 bucks. Does that sound about right? The carpet, dash, and hood aren't quite necesary yet, and from what i can see only 1 cab corner is bad.
both front fenders
all 4 rocker panels
all 4 doors
1 cab corner
interior floor near rocker panel
driver door hinge mounts, both sides (body side, door side, both wiped out on both hinges)
there's probably even more.
magnethead is offline   Reply With Quote
Old 08-05-2006, 01:59 AM   #2
magnethead
magnethead's Avatar
Re: Repair panels?
Old 08-05-2006, 11:09 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Re: Repair panels?
I kind of like the way your truck looks now.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-05-2006, 11:41 PM   #4
magnethead
magnethead's Avatar
Re: Repair panels?
Slonaker
i need at least a left front fender and driver door and rocker panel.....my driver door is literally about to break off..since those pics, i've broken one of the bolts (or so it seems)
Old 08-05-2006, 11:59 PM   #5
f.monroe
f.monroe's Avatar
Re: Repair panels?
Suburbans are pretty common and are pretty cheap . I would look for one in your area and scavenge the parts you need from a Suburban . GM original parts are hard to beat . Suburbans werent usually used too hard and are more likely to be in good condition . Just a thought . Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 08-06-2006, 01:43 AM   #6
magnethead
magnethead's Avatar
Re: Repair panels?
I've been trying to find some but i've only found one in a junkyard so far and it had been pretty well used up. I know everything is a direct crossover for a crew cab.
Old 08-07-2006, 04:10 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: Repair panels?
Front Fenders: I have the GoodMark improved fit fenders (73-80 only) for more at $110.95
Carpet: For a 73-80 Crew Cab ACC kits I have it for $169.95
Dash Hardcover: I have Coveraly covers listed for $92.95, but I had a deal on some, so I can save you more on the ones I have in stock. (depending on the color you need)
Rocker Panel UNITS: Is the the seperate pieces? If so, I have them for $18.50 for OEM fronts and $16.95 for the rear (slip on style) for a full slip on styel it is $26.95 (all for 1 side/each)
Cab Corners: I have these for $14.50 each.
Shipping would depend on your location EXCEPT for the fenders since they have to be truck shipped.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 08-07-2006, 05:16 PM   #8
magnethead
magnethead's Avatar
Re: Repair panels?
the rocker units are a full panel that replaces the existing sheetmetal, 1 piece for the whole side.
76240; all but fenders; blue interior
the rear rockers actually look good, it's from the back side of the B post base to the fender that's pretty much gone or close to it.... so OEM fronts would work except for the back side of the B post base still having the cancer.
except for the dash, slip on/cover up panels just dont work for me. Now if you do have the full origional style dash thats made of a durable material that wont re-crack, let me know cuz i'll take that over the hard cover if the price difference isn't too much. Take note that i dont have the money, i'm just pricing things now so i know how much to save up to get it all without surprise costs.
Old 08-07-2006, 06:08 PM   #9
Jonboy
Slots go on anything!
Re: Repair panels?
What part of the state are you in? What year is your truck? There is a pretty good U-pull-it in Grand Prairie that usually has a ton of Suburbans, which the front doors would work. I am pretty sure Keystone in Garland has the fenders and stuff pretty cheap. The doors aren't bad, either, but I would try to find a decent set of used OEM doors first.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-07-2006, 06:49 PM   #10
magnethead
magnethead's Avatar
Re: Repair panels?
gainesville. Middle of [explenative] nowhere
Old 08-08-2006, 08:35 AM   #11
Jonboy
Re: Repair panels?
Keystone lists most of the other stuff you are looking for in their catalog. They may also deliver to some of the body shops in your area. You might give them a call (972) 764-2272. Free delivery beats the crap out of truck shipping. If you have to ship anything, I would just get it from Chris. That's where I got pretty much all of the sheetmetal on my '73 from.
Old 08-09-2006, 01:12 PM   #12
magnethead
magnethead's Avatar
Re: Repair panels?
found out something. I have metal shop this year (I'm a junior in HS) so if i can, you can bet i'll be fabbing without end on the sheet metal bender and cut-off wheels (will at least allow me to repair the dead pedal and maybe some of the driver front rocker panel, where the gaping hole is)
