changing filter on TH350 Q's
this is my first gm vehicle with an automatic and was wondering a few things......
1) is there a link that shows how to remove/replace the filter? or is it pretty much self expanitory? 2) how many QTS of atf on a stock setup?
'71 LWB 350/350 banana yellow '02 VW GTI turbo 14 sec. 1/4 mile |
Re: changing filter on TH350 Q's
loosen all the bolts in the front half of the pan. let fluid drain. remove all the bolts from the pan, remove pan. take screws out of filter and remove. clean gasket surfaces. place new filter in place with screws. replace gasket on pan, replace pan, retorque bolts.
as far as how much fluid, I am not positive i want to say 6 for a total fluid replacement but don't take my word for it.
I am a proud member of the "No, it's not for sale, I'm gonna fix it up someday" club. |
8 vehicles only 4 that run
![]() Join Date: Feb 2006
![]() Make sure to look for a magnet that may be stuck to the inside of the pan. Sometimes its covered in glop and metallic sludge (hence its purpose), you can pull it off, clean the pan and magnet, then stick it back to the pan. Also, if your filter kit comes with a rubber gasket, sometimes the holes for the bolts can be a tad small. You can stick the bolts through the pan just enough to squeeze through the rubber gasket, and the gasket will hold all of the bolts and keep itself aligned while you put the pan back up.
95 2500 350 w/ 3.73 ![]() 72 GMC 1500 SWB stepside 65 Chevy C10 SWB stepside 72 Chevy C10 LWB fleetside |
thanks guys - do i need any permatex on the gasket?
#5 | |
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
#6 | |
Once the pan is off it will be obvious what you need to do next regarding the filter. If memory serves, 3 quarts will get you going again because the fluid in the torque converter doesn't drain when you do this.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
True, I forgot that older units had plugs. I wasn't sure on the amount of fluid as I had to fill tc as well on mine and I remember buying 4 and having to go and buy some more.
