Old 08-05-2006, 02:30 PM   #1
jasonrmorrow
1972/82/64 disc brake fun !!
Ok i got all the easy stuff done, spindles/control arms/airbags/discs/ yadda yadda left the part i knew was going to be a ***** until last... go to run my brake lines and nothing seems to work. Heres what i got.
- 72 disc hardlines from a truck dealer
- master and booster from a buddy ( i suspect these to be drum/drum though)
- 82 hoses from the caliper to control arm (front of control arm)
The pieces running across the back of the crossmember are easy...well they are easy to place, not connected yet...
I expect to have to do some fitting to get these lines to fit in my 64...but can you help me identify them...here we go
This is the booster/master...equal resevoir size and a prop valve that looks different than the 71-72 disc prop that i bought used...in the next pic.
The lines from the proportioning valve should run down and back towards the cab and then to a "t" near the frame rail on the drivers side... these 3 lines make no sense to me, the one short line i think...goes from the front of the drivers side upper control arm under the engine "tower" to the "t".
THe bottom line has a huge 1/2" fitting on the left side of the pic, no idea where that is meant to fit.
And a pic of my "routing source"
1964 - LWB 350 TPI Fuel Injection
On airbags
jasonrmorrow is offline   Reply With Quote
Old 08-05-2006, 04:30 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: 1972/82/64 disc brake fun !!
Nice work.
dwcsr is offline   Reply With Quote
Old 08-05-2006, 04:37 PM   #3
jasonrmorrow
Originally Posted by dwcsr
Nice work.
Hahaha agh sorry bud i don't think you read the whole post...the finished pic isn't mine, all i have is a booster mounted to the firewall, no brakes yet.
On airbags
Old 08-05-2006, 06:19 PM   #4
68 short step
those lines dont look familure....your refrence truck is a 68 short bed (uses drum/drum brake lines) altho you can see im useing disc all round.
68 short step is offline   Reply With Quote
