Old 08-05-2006, 03:33 PM   #1
msgross
msgross's Avatar
Arrow Steel vs. Poly Gas Tank? which one?
I live in PA with decent winters and salt on the road. Should I ignore the steel tank conversion and focus on the Poly instead? I have only found two places with complete kits $180-$230. Any thoughts would be great. I am moving the tank to the rear frame of course, 68 K-10. Thanks...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 08-05-2006, 04:44 PM   #2
shifty
Questionable
shifty's Avatar
Re: Steel vs. Poly Gas Tank? which one?
i went with aluminum. to make it nearly corrosion free, reduce resonance and more resilient to cracking/breaking, i had the entire tank shot with Line-X bedliner. you may consider the same.
i would personally go steel if aluminum is out of your budget. plastic is easier to install though.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 08-05-2006, 04:55 PM   #3
msgross
msgross's Avatar
how much did the line-x cost on the tank?
The Garage:
Old 08-05-2006, 06:44 PM   #4
msgross
msgross's Avatar
any other ideas?
The Garage:
Old 08-05-2006, 11:08 PM   #5
chevymad
I've got a plastic tank in mine. To do it over again I'd go steel. The tank leaked around the sending unit because of deformation until I used some #2 permatex around it. Also you have to worry about it rubbing through on the frame rails. Used some heavy papermill felt between the 2 there. Rubber mud flap works too.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 08-05-2006, 11:59 PM   #6
BowTieOgre
I had the same question msgross, and since my budget wont allow an aluminum tank im going with a steel kit from either Classic Performance or Truck Shop. Im going to have to buy an external pump to feed the LT1 but I should be able to keep it under $400 with all the parts and shipping. If I have enough $ leftover I may get it coated ala Shifty style.
1986 C10 - LWB, 305/700r4, posi, vortec heads
BowTieOgre is offline   Reply With Quote
Old 08-06-2006, 11:57 AM   #7
msgross
msgross's Avatar
I looked in the FAQ's and found other options. Summit has a 16 gallon cell and hangers for about $180 as well. Truck shop only sells the steel for $180, you may want to coat the outside. GMCPauls, talked to him at Carlisle, has a full kit for $230 (poly, which he recommends). If you are in the south then steel sounds cheaper from truck shop. I can't do aluminum $$$ either. I am leaning towards summit due to the aviation style cap already built in. You would just have to make a door in your bed floor.
The Garage:
Old 08-06-2006, 02:17 PM   #8
badchev69
Active Member
badchev69's Avatar
I dont know if anyone else has this problom but i have the poly tank in both my 72 blazer and my 69 c10 and they both pump VERY SLOW... the inlet neck on them is much smaller than other tanks i have seen. Other than that i have had zero problems.
1969 C10 SWB /350 vortech/th400
1968 SWB build (in progress)
1969 SWB build (my son's future project)
1968 camaro yellow/white stripes (wife's car)
2011 GMC reg cab short bed 2wd daily driver 5/7 drop on 22's
1972 K5 Blazer 13"/11"lift,38"M/T MTZ's, 3" cust exst.
350/350 (sold it )
badchev69 is offline   Reply With Quote
Old 08-07-2006, 12:34 PM   #9
shifty
Questionable
shifty's Avatar
About $60? It will vary from place to place and size of tank. You will need to go to your local Line-X dealer with the tank in hand to get a quote. Takes less than 30 seconds to cure, so you could be in and out in 5 mins.
