cutting springs
can the 69-72 trucks be lowered buy cutting the stock springs?
its all about the +6 inches
Re: cutting springs
in front, yes. in back, it can be done, but way unsafe due to the fact that they are pig tailed on both ends.
laying low
![]() Join Date: Mar 2001
Re: cutting springs
Being a new member you most likely haven't read all the negative feelings on cutting springs. Most will advise you not to do it. Several reasons. New lowered springs are not all that expensive and it will maintain the ride and improve the handling. I read once that an early monte carlo spring would fit and lower the truck but I don't remember the specs.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Re: cutting springs
However...
a properly cut spring, and carefully measured cut, can produce a good looking ride, and not be dangeouse. What one person calls a budget bolt on, ano9ther person calls his whole budget. |
laying low
Re: cutting springs
Now how did I know you'd come back with that?
![]() mgranta, as you see there are differing opinions on cutting springs. Do more research before you drag out the cutting torch though.
Re: cutting springs
Thanks for your help. I was doing some research on cutting springs and conldn't find anything on the topic...changed my searches too cutting coils and found all kinds of opinions...lol I think I will just wait and get the right springs...but I want it low now
Fabricate till you "puke"
Re: cutting springs
Cut coils are fine up front,& you can figure that 1 full round off the bottom will get you 2 1/2-3" of drop. At the rear of a coil spring truck, you can use a 2 1/2" block to lower(tween the diff & the trailing arm). Figure 2 1/2" to be about max on the blocks, or you will be scraping suspension pcs on the pavement tho.....
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
67-72 Addict!
Re: cutting springs
I cut 1¼ coils off my fronts and got between 2¾" and 3" drop. I used a 4" cutoff wheel on a grinder. 4" drop springs on the rear cost about $100. Easy and cheap!
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
senior member
Re: cutting springs
if u want it lowered now cut the coils till you get the lowered coils, that was my philosphy 3 years ago still havent bought the drop coils yet but the ride quality is great and i have no problems i check the spring pockets all the time just in case tho
69 GMC bagged |
Epoxy Primer Friendly
Re: cutting springs
Dont use a torch as it will kill the spring. Use a cutoff wheel or similar to keep the heat down. Another thing with drop springs you may find depressing is the fact that they may not lower your truck if your springs are sagging. These arent new trucks lol Spindles are nice and you can get them in a 3" drop.
