someone PLEASE tell me about my new heads
casting#3782461 "camelback" heads.. just picked them up complete exept springs. for 150.00 they look good someone want to give me what these are? if they are good? thanks alot
1971 k5 blazer 80k mike survivor 1972 3/4 ton 4wd Cummins 12v 1967 swb 2wd 427bbc 1968 4wd shortbox 1971 Cheyenne swb k10 unrestored 1971 Cheyenne super 40k 402bb survivor 1967 Chevy k10 (first truck) 1968 L78 camaro survivor 18k miles 1969 z28 survivor 60k miles 1969 z28 survivor 39k miles 1969 z28 rs survivor 80k miles |
its all about the +6 inches
All my book says is;
307, 302, 327&350 heads from '62 - '70. Sounds liek a garden variety to me. Take them to the machine shop and get hardedned exhaust seats put in. |
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
they are good heads, but they dont have holes for mounting alternator or accessories.
computer illiterate
those are the heads i have and mine have accessory holes
and if you look in super chevy they are doing a test engine called danger rat and those are the heads they are using
72 2wd blazer 72 swb 4x4 |
What date code? Depending on the date (engine application), they could be valuable to someone needing a particular date to match their engine.
If not mistaken, my 65 300 HP vette uses 461s. I might could use an extra pair with Oct-Nov 64 dates...
If James Dean had a truck, it would be a Cheyenne Super... |
BIG VINNIE has the same info I have.I also picked up a set a few yrs. back.I am glad I did cause the performance is awsome compared to the stock heads I was running.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
Just an Old Mr Goodwrench
I had the same question recently . . . Mortec.com lists them as 62cc heads, but my rebuild book says 64cc. Here's the thread on the subject:
http://67-72chevytrucks.com/vboard/s...threadid=20167
1969 CST 20 Longhorn 1970 CST 20 Fleetside 1991 Jaguar Sovereign 1992 Mazda Miata |
I have a set of 461x's according mortec they are;
3782461X...60-63...283/327..Camel hump,no accessory holes,larger 172/64cc port volumes, 62cc chamber These are 2.02's and have bronze guides. stainless valves, screw in studs, and guide plates, and have never been touched with a cutter or grinder. cast dates are D11 2 and D17 2. can't decide to keep em, sell em, or trade em.........oh well, maybe just hold em for now??? |
ebfabman I have a question maybe you can answer, on your heads they have stock Screw In Studs ?? I thought all Fuelie Heads had Pressed in with Bronze Guides!! I do know there are some that came with 2.02 Intakes and some with 194!
I do have a set of 462 Fuelies that I am running on my 68 and all I will say is they are great heads but be warned they will give you High Compression (even with a Flat Top Piston). Might not flow as well as a Vortec but these heads make horse power though!!
1968 C10 Truck LWB Fleetside 1968 C10 Truck SWB Stepside 1994 K2500 Ext Cab Fleetside 2008 Honda Civic Si *lease* |
The only 461 that would have had screw in studs might have been the '68 Z/28. I dug through my Corvette books, but couldn't find info on valve size in print, but if memory serves, the 2.02/1.6 valves didn't show up until 1965. Factory 2.02 heads have an "unshrouding" cut made around the intake valve that bites into the side of the combustion chambers. You seldomly see this in aftermarket installed 2.02 heads.
