Designated A-hole!
What's a Driveshaft for TH400 in a SWB cost?
The title says it all.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
Re: What's a Driveshaft for TH400 in a SWB cost?
if i had the stock drive-shaft, i would just put the turbo-400 yoke on it.
salvage yard parts. cheap. if stock drive shaft is too long now? have drive-line shop cut it and add proper front yoke. they balance it too, p.s if i ever sound condescending in my posts just blame all the good sleep i get and quality coffee i drink. i never mean to talk outside of what i know. i like this web site. life is good. |
Designated A-hole!
I really want a one piece, and evidently this tranny is the HD version with the bolt on yoke. Have to do some checking on that.
It can be converted to a slip yoke style. Otherwise, You'll need a 2 piece shaft. It's gotta be able to slip somewhere.
Designated A-hole!
That's what I figured. I wonder if I can just take the bolt out of the yoke that's on there and let it slip a little?
On the road
![]() ![]() Join Date: Jan 2004
Krue,
You won't be able to use your bolt on yoke without the bolt because it will leak unless you plug it somehow, but you can use a regular slip yoke in it's place. Also there's an o-ring up inside on the output shaft you will have to remove to allow it to slip. You could possibly shorten your existing driveshaft depending on it's construction, I have done this a few times.Take it to a driveshaft shop and let them check to see if they can do it. Mike
Mike Castro- 72 SWB. Ochre and White. 496/400 turbo, GV OD ,Dakota Digital dash , tilt, Vintage Air, PS, hydro boost, factory buckets, console, QA-1 Coil over suspension, 20/20"Billet Specialties Magnetos 72 SWB. Med blue. 454/400 turbo, tach, tilt, Stock AC, PS,PDB, factory buckets, console, ECE 4/6 drop w/ 2" blocks and C-notch, 20/20"Coys- Crashed and destroyed by drunk driver Sept 2019. New 72 build in the works. My new build thread "Castro" https://67-72chevytrucks.com/vboard/...d.php?t=820934 My old build thread, the blue truck http://67-72chevytrucks.com/vboard/s...d.php?t=271489 www.louisianaclassictruckclub.com |
Designated A-hole!
The slip yoke I have is way too small to work with the tranny out put on the 400 I have, do they make a slip yoke to fit it?
Yes they do. I've got a long slip yoke if you need one, cut it to length!
I used the back half of the driveline out of a 78 chev 3/4ton crew cab. It was 3/4" too long, had it shortened, but I may also have my engine mounted further back then you do.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop 70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress |
