Old 08-06-2006, 10:53 PM   #1
krue
Designated A-hole!
krue's Avatar
Starter issues, still
For those that remember I've been having trouble with starters in my truck since I bought it. Pretty much cannot get them shimmed right. The bendix teeth aren't far enough in the flexplate teeth. After a little while the teeth wear and start to clash and bind. I've been thru 6 or more starters in a few years. I had a "special" nosecone that supposedly got the starter .010" closer but the mounting ear broke on it and I can't find another. I replaced the flexplate but that hasn't helped. Any words of wisdom out there?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 08-06-2006, 11:36 PM   #2
jhow66
jhow66's Avatar
Re: Starter issues, still
See if this will help:
http://macc.chevelles.net/starter.htm
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 08-06-2006, 11:43 PM   #3
67chevy2wd
67chevy2wd's Avatar
I am assuming you have the starter with the three tabed nosecone, dont' they bolt to the bell houseing, maybe you bell houseing is messed up. I would try a different one.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 08-07-2006, 12:07 AM   #4
Green Machine
Green Machine's Avatar
I have had the best luck using the cast iron starter noses. But having said that if you have tried a cast nose and that does not work, then use the aluminun nose with this modification.
I have run into this before where maybe the block was machined a little too tall, or the bolt holes were too far outside, which made the starter too far away. Mount the aluminum nosed starter in a vise and use a wide very course file and hand mill some material from the entire mounting surface. How much to take off is your call, I would remove about 1/16 inch and try it. You can always take more off, and if you go too much, oh well, a used nose goes for about $5 around here, or you can use shims. That WILL fix your problem if that is what it is, Just be sure your hand machine job is as flat and even as possible. Make sure you use actual starter bolts too, not just regular bolts.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 08-07-2006, 10:25 AM   #5
tom71
what happened to flint mi
tom71's Avatar
do you have the correct flywheel? if so , i think green machine has the right idea
71 swb 2wd fleet frame off in progress
72 4x4 blazer daily driver
70 olds cutlass s mint condition owned by a grandma
56 gmc 2wd project waitng
97 fiance mobile
tom71 is offline   Reply With Quote
Old 08-07-2006, 10:59 AM   #6
incoma
incoma's Avatar
Starter bolts made the difference for my problem starter. I also have a spare nosecone if you need one.
"Green Monster" (Red Sox fan)
1970 GMC survivor, 350/200 4R, 3.42 rear gears, 2.5/4 drop, ECE disc brake conversion, powder coated suspension
incoma is offline   Reply With Quote
Old 08-07-2006, 06:57 PM   #7
kaycee
kaycee's Avatar
I had to shim my starter on the outer bolt only(closest to pass. fender) it worked for me.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 08-07-2006, 08:54 PM   #8
krue
Designated A-hole!
krue's Avatar
I've shimmed the starter on an engine stand and can't get it close enough. Guess I'm gonna have to try the file method. I used a grinder on one, but I may not have gotten it flat enough.
www.daveramsey.com
Old 08-08-2006, 05:13 AM   #9
Americanrider
I ran into the same problem replacing a rebuilt SB400 in a '73 Caprice last year for my cousin. I ran the numbers on the block and it came back as a '75 1 ton truck motor. So after another quick trip to the parts store for an exchange (4th time) I pulled all the shims, installed the starter it called for and it worked great and is still working.
Americanrider is offline   Reply With Quote
Old 08-08-2006, 05:05 PM   #10
JustLiveIt
JustLiveIt's Avatar
PO of my truck put the flex plate on backwards so the pinion on the starter barely hooked up with the teeth on the flex plate. Now it just grinds and the starter and flexplate need to be replaced.
Not looking forward to that one...
1968 Chev SWB Fleet with GMC Clip and lots of 71-72 parts!
JustLiveIt is offline   Reply With Quote
Old 08-08-2006, 06:04 PM   #11
67chevy2wd
67chevy2wd's Avatar
Look on the bright side it could be in a front wheel drive with a transaxle, now that would be fun.
'71 GMC 3/4 ton 4x4
Old 08-08-2006, 06:28 PM   #12
JustLiveIt
JustLiveIt's Avatar
True. But with just a small garage and jack stands this should be a fun one.
Old 08-08-2006, 10:22 PM   #13
krue
Designated A-hole!
krue's Avatar
Beats my yard and gravel drive.
www.daveramsey.com
