Old 08-07-2006, 09:14 AM   #1
Dean
Dean's Avatar
K30 front sway bar help
Does anyone have any tips on installing the two new bushings on the front sway bar on my 87 K30? I got new ones from Moog but having no luck on getting them in. Thanks
Dean is offline   Reply With Quote
Old 08-07-2006, 10:44 AM   #2
ben@speedbarn
Done yet?
ben@speedbarn's Avatar
Re: K30 front sway bar help
Are you changing the ones where it mounts to the frame or where it bolts to the spring? I changed the ones on the frame. I just unbolted the brackets, removed the old ones, spread some anti-sieze where they were going and popped the new ones on. They were split so you didn't have to slide them on from the end.
'76 k2500 -- almost done...
ben@speedbarn is offline   Reply With Quote
Old 08-07-2006, 12:50 PM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Mine went on my half ton just fine. If you are having problems, could it be that you have the ones for a smaller bar?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 08-08-2006, 07:09 PM   #4
Dean
Dean's Avatar
I'm trying to change the ones that bolt to the spring mount. The inner ones you talk about are the easy ones. They are a large rubber piece with a center inner steel piece. There must be some way to compress this rubber to get it in.
