08-07-2006, 10:20 AM | #1 |
Put some time in on wife's 68 this weekend.
New pic on last page!
We all put some hard time in on my wife's 68 swb this weekend. This truck was red Friday afternoon! While my wife and son were running sanders I was switching between bodywork and fabrication. Everything is ready now for the 20 gallon S-10 Blazer fuel tank to be put in. The best part is it doesn't hang as low as other tanks, and the gas gauge even reads right! I'll finish bodywork and have it in primer by Thursday. In time for the big cruise in Branson Mo. Last edited by Myself; 08-21-2006 at 09:51 AM. Reason: To add info. |
08-07-2006, 11:00 AM | #2 |
Happy Camper
Re: Put some time in on wife's 68 this weekend.
Too cool
RIP El Jay! Love you brother! |
08-07-2006, 12:56 PM | #3 |
Just here to help
progress is sweet! When is the big Branson cruise?
08-07-2006, 01:14 PM | #4 |
Very Nice. I'd like to see more about the S10 tank install, ie how she sits in and the fill nozzle...all the neat stuff.
08-07-2006, 01:25 PM | #5 |
i just fell in love with that truck. it has the same wheels as mine so it reminds me of my truck a few months ago. i want to do some bodywork.
08-07-2006, 01:57 PM | #6 |
The Shephard of the Hills car show and Super Summer Cruise is this weekend!
08-07-2006, 03:37 PM | #7 |
Ya, I'm with Palf, lets see some pictures of the S-10 tank. I've got a donor Blazer but didn't know what I'd run into using the tank.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
08-07-2006, 04:08 PM | #8 |
WTB this ad
+1 on the S-10 Blazer tank install. I would also like to get the tanks out of the cabs of my trucks. I just always thought that the full size blazer tanks hung down a little low for my taste. ECE makes a sweet fuel cell that's up high but the price is on up there!
08-07-2006, 04:48 PM | #9 |
The truck is great, but the best part has to be finding a wife who understands the value of an old Chevy truck. My wife won't even ride in mine of course I haven't done much work on it yet. I bought her a new pair of BIG diamond earrings so she won't go crazy when we get the credit card bills for the parts I have bought. I love my wife and she is great but if she told me she wanted a 68 Chevy to restore I would probably fall over with a heart attack.
Jeremy |
08-07-2006, 05:36 PM | #10 |
Well, it's only fair. I have an S-10 Blazer that I put a smallblock in and spent a lot of time and money on it. Then, summer before last I bought a Trans Am off E-bay and went to San Diego to get it. Then when we got back I did a little body work on it and painted it. (She did get a vacation out of that, does that count?) She decided she wanted one of these old trucks so, here we are. Fair is fair. And I've already redone the motor, trans, and brakes too.
08-07-2006, 07:03 PM | #11 |
Looks good at 20-ft .....
Hey, Myself, where in North AR are you located ?
I'm in Mtn Home. |
08-08-2006, 01:29 AM | #12 |
You should do a tech write-up on the install of the S-10 tank, I'll bet there are plenty of them in the j-yards. Thanks.....
70 LWB, 350/350 A/C, P/S, 3 Tone Paint (white cap, primer gray with black guide coat) |
08-08-2006, 04:49 PM | #13 |
WTB this ad
It looks like you made a pretty good size cut on either frame rail and welded in a brace at the rear of the frame. Do you have any pics with the tank installed?
08-08-2006, 05:36 PM | #14 |
The LuvShack Garage
Progress is Progress, no matter how much or how little, Nice work
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
08-14-2006, 06:16 PM | #15 |
Okay, I was working on the truck all last week and got it in epoxy primer. Spent many hours with a long board. The fuel tank is in and looks good from behind, although if I did it again I would do a couple things different. First off the S-10 Blazer tank needs mounted with the fuel filler neck towards the driver side. With it on the passenger side it sits just in front of the rear bed crossmember. That's more cutting and a longer tube to bend for your filler. Also don't mount your filler cap onto the bed floor. The fuel won't drain fast enough and it takes a million years to fill up! I'll have to reposition it higher. Other than that it works great. I left the factory fuel pump in the tank with no problems. The mechanical pump will suck fuel right through it. The rear bed crossmember will have to be notched out, and in my case notched a little higher in the area right above the sending unit. The upper front part of the tank straps will bolt right to the frame after you drill holes. The lower front of the straps need about 1 1/2" spacers bolted to them to drop them down a bit. I cut a couple from square tubing. The rear frame crossmember needs removed and a new one put in place farther back. I used 1 1/4" thickwall angle and welded it inside the frame towards the bottom. That way you can still bolt your bumper back on. The top and bottom tank straps will bolt to your new rear crossmember together after you drill the rivets out of the upper straps and unfold the doubled up part. Then just enlarge the last hole. Don't forget to drill a small hole for your ground wire! Also, some 3/8" rubber fuel line slit lengthwise works good as an isolator to keep any parts of the tank from rubbing on the frame if you mount it that close. Here's some pics.
08-15-2006, 10:02 AM | #16 |
Some more pics.
08-15-2006, 10:24 AM | #17 |
Man, that looks great!
You said the truck was in primer??? So you cleared the primer, or is the last pic paint? Looks good either way. Post some pics with the back bumper on so we can see how low the S-10 blazer tank sits when you git r done
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-15-2006, 11:14 AM | #18 |
In the last pic it had just got done raining. It's black epoxy primer.
08-15-2006, 11:49 AM | #19 |
Designated A-hole!
I like the blazer tank! Definitely need a FAQ write up on that one.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
08-16-2006, 12:07 AM | #20 | |
I think the world needs a drink... Help somebody...If you can....VanZant We're not wrong, we're not sorry, and its probably gonna happen again. That's the truth about men. Tracy Byrd Member# 13924 '70 c10, 350/350 '68 c10 250/4spd '68 c10 no eng/trans fac ps/pb/ac/at (future father/sons project) '48 Chevy Loadmaster |
08-16-2006, 12:36 AM | #21 |
So if I put in an S10 Blazer tank with the fuel pump in place, I can just run the mechanical pump and pull through the e-fuel pump. And later if I go with an EFI, the e-fuel pump is already in place. One of those two-birds-one-stone deals.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
08-16-2006, 09:28 AM | #22 |
Yes, fuel pump in place, everything as factory, the mechanical pump will suck fuel right through it no problem. I'm pretty sure all 83-94 S-10 Blazers, S-15 Jimmys, and Olds Bravada have the same 20 gallon tank. Only 86-up will have the fuel pump in tank.
08-16-2006, 11:25 AM | #23 |
Page intentionally left blank.
Nice work, good job on the tank as well! I'm going to keep this in mind for my tank swap plans. Thanks for the info!
There is a theory which states that if ever anyone discovers exactly what the Universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarre and inexplicable.There is another theory which states that this has already happened. - Douglas Adams '67 GMC 4x4, 305 V6! Or all the parts for anyway... '17 Subaru Outback. '18 Toyota Tacoma TRD Off Road. '99 Ducati 900SS. |
08-16-2006, 11:29 AM | #24 |
C10 Club Tennessee
Ditto, we need a FAQ written on this. S10 Gas Tanks are SUPER CHEAP at the pull-a-part in Nashville. They are also plentiful.
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
08-16-2006, 04:09 PM | #25 |
WTB this ad
I would also like to see how low it hangs below the bumper. Keep us updated!
