08-07-2006, 12:42 PM | #1 |
Master Cylinder ?
not loosing fluid but have to continually pump the brakes to keep the pedal hard is that the MC that needs to be replaced??
08-07-2006, 01:21 PM | #2 |
Re: Master Cylinder ?
most likely
08-07-2006, 01:44 PM | #3 |
its all about the +6 inches
when you hit the pedal initially, is it high and works good...then it slowly sinks down?
If so, get a new master cyulinder. If you have to pump it up just to get a high pedal (it goes to the floor first time you hit it) then you need to bleed the brakes. |
08-07-2006, 02:45 PM | #4 |
thanks all....
