08-07-2006, 05:22 PM | #1 |
Back in the sticks
Need Tilt disassembly help...
Been trying to pull the two pins out of the sides of the column. The one you screw the 8/32 screws into? I got one to pull out like that, but the other will not budge. I've broken about 30 of the screws trying to pull it. Tried screwing it, slide hammer, you name it. Anyone got a better idea? This is a van tilt that I am converting to floor shift by the way. Thanks, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty Last edited by red71cheyenne; 08-07-2006 at 05:23 PM. |
08-07-2006, 05:49 PM | #2 |
Re: Need Tilt disassembly help...
Probably just stuck in there, sounds like the same setup as in my beretta, when I took that apart the one pin was kind of stuck, I just jerked it around and pulled and it came. Move the tilt up and down and pull.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
08-07-2006, 06:06 PM | #3 |
member #16
You will need a pin puller. They work pretty good on tight pins. Most tool brands have one.
http://www.skywaytools.com/autopg1.html
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
08-11-2006, 07:58 PM | #4 |
Back in the sticks
Thanks guys! I'm ordering one now. Hopefully I'll get it soon and get the column pulled apart finally. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
11-06-2006, 09:29 PM | #5 |
I've been looking over this one again, I know I need a pin puller tool to redo my tilt, but do I need the lock plate tool also to get my tilt apart? This is my first time at rebuilding one of these guys. Thanks
11-06-2006, 09:40 PM | #6 |
member #16
Bill unless you have a newer locking column you wont need the lock plate tool.
11-06-2006, 09:53 PM | #7 |
Thank you, that is what I thought, but I am just the shade tree mechanic without a shade tree. No it is just a standard 72 truck tilt.
