08-07-2006, 09:22 PM | #1 |
86 firebird column in a 69- inovative thinkers
Can it be done
08-07-2006, 09:35 PM | #2 |
its all about the +6 inches
Re: 86 firebird column in a 69- inovative thinkers
Do you have it there?
What's the total length? You planning on hooking up the column ignition switch? How about the wipers and high beam switches? You'll have to cut the bottom of the dash and the inst panel too due to the added diameter of the column. |
08-07-2006, 09:56 PM | #3 |
thanks for the input I will measure the column in the morning
08-08-2006, 09:08 AM | #4 |
I used to drive an '86 camaro... aren't these columns a little, ummm, thick?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
08-08-2006, 09:11 AM | #5 |
Yup, that's why I mentioned cutting up the dash for the added diameter.
Are you looking at this just to add a tilt, or do you want to remove all the stuff from the dash and have it all on the column? |
08-08-2006, 10:34 AM | #6 |
I like the c-10 alot!!!!
but my first love is tpi in a bird. I really like the column and wouldnt mind having the same column in my truck that I have grown to love in all 9 of the birds I have owned from the end of the shaft to the end of the horn measures 36 1/2 inches I took a bunch of pictures but the pit bull ruined the cord to my computer last night chasing the cat. I am learning that this is my fault for leaving it out. It took me 30 years to begin to realize that most bad things that happen to me could have been avoided if I took extra measures instead of putting the blame elsewhere now that I am off the soapbox I will post the pictures later on this evening |
08-08-2006, 12:11 PM | #7 |
I have a 80 trans am in mine. i love it!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
08-08-2006, 12:43 PM | #8 | |
You know better than that....... PICTURES!!!!
08-08-2006, 01:45 PM | #9 |
http://67-72chevytrucks.com/vboard/s...d.php?t=184375
you bet. It is covered in garbage bags ready for paint, or I would get better pics.
08-08-2006, 11:20 PM | #10 |
I need more ideas
I also forgot to go to best buy because my grand prix is eating altenators Its my hoopty so I think I will have it rebuilt to just use a one wire setup like the one I put on my c-10 long story short I still cannot post pictures Last edited by jamon8; 08-08-2006 at 11:21 PM. |
08-09-2006, 07:49 PM | #11 |
i put a 1994 chevy pickup colum in mine it works great i love it but it took forever to hook up and install but now its done
08-10-2006, 08:28 AM | #12 | |
Man it takes time to get it right! Then the wiring switch #$%^ But it is all worth it to have tilt and a nice wheel
08-10-2006, 10:43 AM | #13 |
if titl is all you are looking for, there's MUCH easier ways about it. Hell I have a couple tilt columns right here for sale.
08-15-2006, 08:21 AM | #14 |
here are the pictures that I have been waiting to post
buy the way prices for the camera cable Best Buy-35+tax ebay-9.90 to my door in 2 days |
08-15-2006, 08:23 AM | #15 |
more pics
08-15-2006, 09:26 AM | #16 |
yep that looks verry similar to the chevy colum i put in mine on the end of the colum i think you should cut the otiginal bracketry that holds it to the fire wall in order to get it through the hole in the wall
08-16-2006, 09:45 AM | #17 |
bump
08-16-2006, 06:15 PM | #18 |
it take a while but can be done cause i did it
08-17-2006, 10:39 AM | #19 |
the columns are about the same size. all I need to do is wire the ign, turn signals and wipers.
I want to cut the 86 column wires right before the plug and splice the connector of the 69 column so it would plug right into the harness. I was also thinking of plugging the 86 bird fuse box into the truck and rewiring it for updated equipment |
08-17-2006, 01:16 PM | #20 |
I got the wiring diagram from a chilton book for the 80 colum and then just matched up the wires to the 67
You will probaly need a custom dash bezel to fit over the larger colum shaft
09-20-2006, 08:15 AM | #21 |
my buddy is the shizzel!
he had the idea a couple of days ago to put the turn signal wiring from the old 69 column into the 86 column. I was just going to splice wires trial and error style but the column had to be taken apart to tighten the tilt mech. he took the base of the 69 turn signal mech and mated it with the upper part of the 86 mechanism I know I know pics right! you can blame my rechargeable batteries "I hate them so much"-HOMER heres to eddie, I wouldnt be able to do it without him |
09-21-2006, 12:17 PM | #22 |
the battery situation just got a bit better
09-23-2006, 01:08 PM | #23 |
it all works
left the wipers on the dash |
