cab swap question
Hello, i am doing a cab swap on my 69c10 with a 68 high hump cab. I just took off my front clip yesterday and i noticed one huge difference between the two cabs. I noticed that the fuse box location on the firewall was different and the fuse block on the 68 cab is horizontal, unlike the vertical one on the 69 cab. my question is i want to keep the wiring from the 69 cab and put in the 68cab and also the 69 foot parking brake i would like to put in the 68cab but the firewalls are different, has anyone here ran into this and what did they do to the cab to put the 69 and later foot parking brake assembly in? any info would be greatly appreciated.
#2 | |||
Union Electrician
Re: cab swap question
I believe the wiring harnesses are the same,just mounted differently. No help on the parking brake.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
ttt
Only way I know to accomplish this is to cut out that section of firewall and weld back in the 69 section. The fuse panel 68 is in the way of the park brake area if left as is. also not to sure a 69 fiuse panel will bolt into 68 opening as I think bolt holes are wrong.
Have included pics of both firewalls and park cable locations
![]() Join Date: Aug 2001
i need to know more about this too since i'm going to be swapping a 70 cab for a 67.
blood type; Retumbo
stop by with the cab and I can set you right up with a solution.
you still know where I live? |
If I rememver right the harnesses are different too. The wires don't come out the same, I am not saying it won't work I just think they are different.
07 Chevy classic LBZ Duramax (a few mods) '67 Chevy 1/2 ton 2wd (in pieces) '69 Chevy 1/2 ton 2wd (on hold) '71 GMC 3/4 ton 4x4 ‘71 GMC 1/2 ton 2wd suburban |
