Old 08-08-2006, 07:56 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Tips for installing hood anit-rattle foam.
I am going to install that repop hood anti-rattle foam on my 72. Anyone have any tips? I was thinking about using some 3M weatherstrip/emblem adhesive, on it to hold it in place.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 08-08-2006, 08:33 PM   #2
Sweet72
Sweet72's Avatar
Re: Tips for installing hood anit-rattle foam.
I used 3M black super weatherstrip adhesive along the edges after slipping it into place.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
Old 08-08-2006, 10:09 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Where is the best place to put them?
Old 08-08-2006, 10:27 PM   #4
kwmech
I was thinking the other day about using some expanding spray foam and fill up the whole length of the channel. My hood is doing the wobble thing on the freeway. It'll help keep out the wasp nests also when the truck sits for a couple of weeks at a time. Any thoughts on that?
Old 08-08-2006, 10:35 PM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Ya, the foam would probably work. Then after the foam sets up and expands, just spray bomb it black, and you'll probably never notice it.
Old 08-08-2006, 10:43 PM   #6
kwmech
I figured the same--after it sets up I could cut the x-tra off and clean up the edges then paint.
Old 08-08-2006, 11:59 PM   #7
ERASER5
ERASER5's Avatar
Be sure to use LOW expansion foam. Some of that stuff could warp your hood if sprayed into the channels.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
