Old 08-08-2006, 10:12 PM   #1
pv68
Junior Member
pv68's Avatar
383 stroker
I have 383 stroker long block w/12 to 1 comp, brodix -8 heads, crane roller rockers, crower flat tappet #00351 INTAKE: Duration: 288º Lift: 0.525 EXHAUST: Duration: 292º Lift: 0.543, speed pro forged flat top pistons, forged I beam rods and nodular crank. The block is a 1peice seal. The assembly is fresh no run time.
aking $2500 obo
pv68 is offline   Reply With Quote
Old 08-08-2006, 10:16 PM   #2
Lizzard27
Re: 383 stroker
pics please
Lizzard27 is offline   Reply With Quote
Old 08-08-2006, 10:37 PM   #3
bigjimzlll
bigjimzlll's Avatar
Re: 383 stroker
Hi ..nice looking engine. How does it have 12-1 compression ratio with flat top pistons?
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 08-08-2006, 10:45 PM   #4
pv68
Junior Member
pv68's Avatar
Re: 383 stroker
The heads are milled down to 58cc. The engine builder calculated the compression ratio.
Old 08-08-2006, 10:55 PM   #5
67chevy2wd
67chevy2wd's Avatar
Re: 383 stroker
That looks like a hell of a deal. Someday I will have a stroker.
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 08-09-2006, 09:18 AM   #6
Ole Blue 68
Ole Blue 68's Avatar
Re: 383 stroker
And so close to me....Wish I had the $$
Ole Blue 68 is offline   Reply With Quote
Old 08-09-2006, 11:35 PM   #7
pv68
Junior Member
pv68's Avatar
Re: 383 stroker
need this gone
throw me a decent offer!!!
Old 08-10-2006, 06:37 PM   #8
pv68
Junior Member
pv68's Avatar
Re: 383 stroker
price lowered to $2200
Old 08-15-2006, 04:48 PM   #9
aggiedave98
Re: 383 stroker
anybody have estimates on what kind of HP and torque for this?
this probably won't work in a 89 suburban w/ TBI with the stock computer or would it??
aggiedave98 is offline   Reply With Quote
Old 08-15-2006, 05:57 PM   #10
Werewolf
Woof?
Werewolf's Avatar
Re: 383 stroker
Stock computer would need to be tuned to get the most out of the engine. Sometime in the late 80's GM tapped a hole in the water jacket of the blocks for a knock sensor. If this engine isn't tapped for a knock sensor (probably not) then you couldn't use one, and the computer would throw a code unless you had that system disabled. That sensor is part of the ignition control system.
1968 LWB CST BB
2004 Avalanche Z71 LT3.
2003 S-10 ZR2 (hers).
1997 Astro
1992 Caprice wagon, 500k stock miles. Nursing wounds after a bad wreck.
1997 Saturn - need gas mileage from something!
Werewolf is offline   Reply With Quote
Old 08-16-2006, 12:22 AM   #11
pv68
Junior Member
pv68's Avatar
Re: 383 stroker
engine was built to have 500 hp.
Price lowered to $2,000
Old 08-16-2006, 06:24 AM   #12
ratrod67
ratrod67's Avatar
Re: 383 stroker
Wow! That's a screaming deal. Those heads are worth most of that $2000 asking price.
ratrod67 is offline   Reply With Quote
Old 08-16-2006, 08:47 AM   #13
67GMCMatt
Re: 383 stroker
with 12 to 1 compression will that thing even run on pump gas?? Are you willing to ship this engine?
67GMCMatt is offline   Reply With Quote
Old 08-16-2006, 08:53 AM   #14
aggiedave98
Re: 383 stroker
Guys,
I'm in Houston and am looking to build a 383 for my '89 Suburban but wanted to use pump gas. Do I have any options here? Would it be worth getting this to reuse any of the parts? I assume if the heads are ground down, then I'm not going to be able to get 9.5:1 or so, right? Sorry for the dumb questions.
Old 08-16-2006, 08:54 AM   #15
aggiedave98
Re: 383 stroker
I guess what I should have said is 87 octane...
Old 08-16-2006, 09:09 AM   #16
bigjimzlll
bigjimzlll's Avatar
Re: 383 stroker
The short block has flat top pistons. Heads with 72-76cc would net you 87 octane friendly. I imagine you could buy the engine and sell the heads easy enuff to but a set with bigger chambers.
For a lower compression engine the cam would be a little on the big side. It is just right for 12-1.
Anyways, you couldn't build this engine for 2000.00
Anderson,CA
Old 08-16-2006, 06:14 PM   #17
pv68
Junior Member
pv68's Avatar
Re: 383 stroker
You definitly can't build this engine for 2 grand (trust me) and It will need racing gas. Shipping will probably be 300+ dollars.
Old 08-20-2006, 11:42 PM   #18
HUEVUDO
HUEVUDO's Avatar
Re: 383 stroker
I also live in DP i have the yellow and red trucks. I have never seen your truck. Do you still have the engine for sale? I will only run on race fuel right? How much for the engine?
HUEVUDO is offline   Reply With Quote
Old 08-20-2006, 11:53 PM   #19
pv68
Junior Member
pv68's Avatar
Re: 383 stroker
sold
Old 08-21-2006, 12:02 AM   #20
HUEVUDO
HUEVUDO's Avatar
Re: 383 stroker
just my luck i blew my red 68 the other night
