Old 08-08-2006, 10:47 PM   #1
kna4977
67-72 A/C Flapper Question????
I am trying to install factory A/C in a non factory A/C truck. I've looked through the Service Manual and Factory Assembly Manual and cannot find anything about a cutout for the flapper that fits in the cowl in the Factory A/C system. Does anyone know if I need to cutout for this, and if so, what is the best way to do that? Better yet, does anyone have any pictures? Thanks for your help.
kna4977 is offline   Reply With Quote
Old 08-08-2006, 11:02 PM   #2
67chevy2wd
67chevy2wd's Avatar
Re: 67-72 A/C Flapper Question????
Check this link out, I think it has what you want.
http://67-72chevytrucks.com/vboard/s...d.php?t=207799
07 Chevy classic LBZ Duramax (a few mods)
'67 Chevy 1/2 ton 2wd (in pieces)
'69 Chevy 1/2 ton 2wd (on hold)
'71 GMC 3/4 ton 4x4
‘71 GMC 1/2 ton 2wd suburban
67chevy2wd is offline   Reply With Quote
Old 08-09-2006, 12:39 PM   #3
mrein3
mrein3's Avatar
No cutting required. Just get a donor flapper. Take a good look at how it was mounted in the junk truck. Make note of the size of the holes. Your truck has dimples from the factory on where to drill the three holes. The flapper is the easier part of this swap.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 08-09-2006, 01:38 PM   #4
JimKshortstep4x4
Here are some pics of the flapper door as it is installed.
Jim
Old 08-09-2006, 03:28 PM   #5
John Fabris
TOTY 2006
John Fabris's Avatar
Hey Jim, that spring is in the wrong hole!! It should be in the one to right, just below the wiper shaft hole....
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 08-09-2006, 09:00 PM   #6
kna4977
Thanks so much, those pics will help a bunch!
Old 08-09-2006, 09:16 PM   #7
JimKshortstep4x4
Talking Re: 67-72 A/C Flapper Question????
Good eye John!
I did move the spring before I installed the cowl clip.
Jim
